Does anyone know how to fix the extremely dumb electronic design on BMWs that means the AC is on, even if you turn the button marked 'AC' off?
Infuriating. If I want it off, why is it still on?
Probably humidity dependant or you have it aimed at the screen or something.Does anyone know how to fix the extremely dumb electronic design on BMWs that means the AC is on, even if you turn the button marked 'AC' off?
Hold the fan speed button in the down position for a second and the unit will shut itself offDoes anyone know how to fix the extremely dumb electronic design on BMWs that means the AC is on, even if you turn the button marked 'AC' off?
I have had a google, and it appears it is common. Pressing the AC button off (so the light is not illuminated), does not actually turn the AC off.
I am a bit weird and occasionally drive with windows down, but want some hot air or similar, during which I definitely don't want the AC on.
Interesting, I will give it a go next time, but I am pretty sure it will continually pump cool air due to a different setting on the HVAC controls - this is what I have noticed, and some people online have also reported.It does though. That is the function of that button - if you switch that off the compressor stops running. It'll take a while for the residual cold air in the system to disappear, though.
So driving with windows down and AC on is the way to do it?It does though. That is the function of that button - if you switch that off the compressor stops running. It'll take a while for the residual cold air in the system to disappear, though.
But actually, you do. You shouldn't ever need to switch the air conditioner itself off - it dehumidifies the air as well as cools it, and is reheated by the car if your desired temperature or setting doesn't call for cold air. There is no need to ever switch it off really - it's good practice to leave it on, as it keeps the system in full working order. Depending on the car, you can over-ride the face level vent temperature to be only hot air if thats what you want regardless of the air conditioning.
But if you really want to, then that button will do it
What's wrong if the AC doesn't turn off? I never turn my AC off, even with the windows down.Seems strange to me I will be honest. The system will think the air is not reducing in humidity, so will keep the AC on
What are the thoughts on a 630D GT 2018? I'm looking to "downsize" from a 2022 VRS Kodiaq and whilst the 6 is actually a bigger car it just looks a lot better as a cruiser and also on fuel especially now I no longer need 7 seats. Is there anything to look out for on these?
But this isn't a problem. It won't throw chilled air at you just because the air conditioning is running.
If I have the dash control dial on cold, and the temp set to say 21°, it will chuck cold air at me
want some ambient temperature air blowing in my face
Will that dial control whether AC turns on/off as well?...so don't put the dial on cold?
This is what it appears to do. If I have the dash control dial on cold, and the temp set to say 21°, it will chuck cold air at me with the windows down.
