No they won't - I think they'll only do it if it's due within 1,000 miles.
Its only an hypothetical example but that would mean the service pack has 14000 "wasted" miles then!! That's a pi** I think...
The normal sound is synthetic, is it not?
Well as far as the VIN number information can provide I couldn't see much else that was missing from cars... maybe fully specced wasn't the right words, but it certainly has a lot of goodies... Far more than the current 1997 Scooby legacy RSB!
Can anyone who has owned an E46 at some point help me out?
My 328i has a few problems with idling. When stationary for longer than 45 seconds, you start to feel a few light vibrations and the RPM may dip and rise every so slightly. This tends to get worse the longer you are sitting there not moving, but will be OK once on the move again, with the cycle to repeat once again at the next stop. Last week, after about 4 minutes idling, there were some severe vibrations that felt like there was a misfire, this did not imporve several hundred feet after setting off so I restarted the engine and all was well once again.
The car is fine when you set off again, apart from the instance described above. Its rather annoying and I would like to fix it so I have a lovely and smooth idling experience.
There are no warning lights of any kind showing up and I'm not sure if the early E46 (1999) have ODB2 ports, allowing me to check for codes with an adapter.
I intend to take the MAF sensor off and see if that lets it idle any better. If it does improve, apparently this may indicate a vacuum leak somewhere. The next job after this will be checking the DISA for any wear and cleaning the Idle control valve, hopefully this wont be too challenging considering I haven't previously worked on a car.
I don't believe the DISA or VANOS is the problem as the car feels very smooth and rev's well to the top of the range.
The internet is awash with many similar symptoms, though it would be nice if anyone on here could share any similar experiences.
They should on their 4 pots, not a nice sound
Rear spring?
Ah didn't know it was ECU based, so it's sort of similar to those ciggy lighter socket things that pumps out engine sounds based on the current flowing through that were doing the rounds several years ago?
Edit*
This doesn't mean I'm pro the idea, fake sounds are fake sounds regardless. With regard to sound proofing, what's different about it versus previous generations? The engines are quieter, not the sound proofing being heavier. Turbo charging is the reason. But if Mercedes can do it right without fake sounds then why can't BMW?
I can't believe what I'm reading, new BMWs play attractive engine noise effects through the speakers?? Pull the other one!
550i, my company car for the weekend. I didn't think I'd get to experience a car of this power until I was a lot older and I have to say. Wow.
Its very comfortable to cruise around in but when you plant your foot the power this V8 delivers is absolutely brutal.
Took me most of today to stop being terrified and start to enjoy hooning in it!
Drangueos, this one will be for sale soon. Around £7k, a serious amount of car for the money. With all the extras (it has most if not all) the car was around £60k new! (Ouch) I'm tempted myself!
