[TW]Fox;22886300 said:
I'm not defending BMW on the wheel cracking issue here but you can see the point they have? You have a set of used wheels from a different trim level on your car - which you cannot provide proof you bought from BMW (Because you didn't).
To me, this is irrelevant. Just because the BMW factory didn't screw in the bolts, should not mean that they are of less quality or subject to less goodwill IMO. They are BMW wheels, they should be subject to the same quality assurance as those that came from the factory.
All i want is a run out test - if it fails this, i will happily pay for a new alloy myself, but i have a feeling it will pass this test.
They are therefore seperate to the car and its warranty - its basically a set of used Ebay wheels which you are trying to get replaced. Why would they do this?
I'm not trying to get it covered under a warranty. I'm trying to get it covered as goodwill on BMW's part, pending a run out test. Used ebay wheels - aren't all wheels "used" as soon as they've been driven a few miles? I'm sorry, but if i swapped my MV3's on to my mums car and she took them in they'd replace them in a heartbeat. Why does it matter where they came from? They are OEM BMW manufactured wheels that have failed - and i want them to do the run out test to prove it was due to a manufacturing fault.
Why should they do it? Because i spend thousands of pounds with BMW? Because I am a brand loyal customer? Because I have full BMWSH and a fully comprehensive warranty? Because there is a well known problem with BMW alloys of this era?
IMO, they are being difficult. I've told them to inspect the alloy if they don't believe they are genuine as the replica's aren't that great.
Are they not 18's too, I was under the impression the MV3's were not affected by the cracking design flaw the
19's were.
They are 18s and although the problem didn't afflict the 18s anywhere near as much as the 19s, the MV3 is still a wheel which frequently cracks and many others have had cracked MV3's replaced under goodwill as a result of a successful run out test. BMW switched suppliers of MV3's at some point and the new MV3 alloy wheels BMW provide should not crack.
Have they perhaps cracked for another reason thats not related to this?
Unless they give me a run out test - we'll never know.
