braking going off an exit slipway, especially with a load of temporary signs up, is not unpredictable, it's exactly the behaviour i'd expect. 144 posts and other than the op you're the only person that thinks the audi driver is in the wrong. called it before, calling it again. you're the op, ain't ya??you don't do things that are unpredictable(stupid, as i said) for others,
oh jesus, you're one of them! probably shoulda tapped them harder, would have saved you from the bollardsfor example if I see someone too close for the braking I will soon be doing I'll tap the brakes, to wake them up
an experienced driver - yes.oh jesus, you're one of them
ahh makes more sense now. experience does not automatically make for a better driver. when someone trots out the old 'i'm an experienced driver' line it's usually just after they've caused an accident that they are trying to claim isn't their fault. like crashing into a bollard close to an exit slipway!an experienced driver - yes.
What jpaul said is totally sensible. Tapping the brakes does not mean, braking. A quick tap will make the brake light come on and warn the tailgater to back off. That is much safer than suddenly braking for real.ahh makes more sense now. experience does not automatically make for a better driver. when someone trots out the old 'i'm an experienced driver' line it's usually just after they've caused an accident that they are trying to claim isn't their fault. like crashing into a bollard close to an exit slipway!
Be careful doing that. If your tap is a little too much you might cause the tailgater to try and overtake, end up in lane 1 rather than on the slip, get confused and decide that the best way to resolve the situation is to drive straight into the nearest barrier.A quick tap will make the brake light come on and warn the tailgater to back off.
Are you on glue ?erratic and unpredictable driving isn't for the roads
the cones getting ran in to and the beacons flying up in the air in the last seconds is just comedy, at least you missed the big metal framed sign I suppose
but....it does kind of look like the Audi had made a mistake and was planning to turn back on to the motorway since you were right behind them looking like you were taking the slip... maybe there was enough distance to the car behind you for them to get back on the motorway...then they see you alongside them and assume you've made the same mistake and will be continuing on the motorway so commit to the exit slip since the 'other vehicles were coming fast' like you say
Are you on glue ?
Are you on glue ?
not on a school night
