- 25 Nov 2009
I've been dealing with OCUK direct.
Do you not need only 8 for a push/pull config? Each fan needs 4 of the long screws that pass through the fan and screw into the radiator, so 8 should be enough for a fan on both sides, or am I missing something?
You dont need any more screws than what it comes with. the smaller screws can be used to secure the fans on the botom of the unit, all you need is a screwdriver thin enough to fit through the screwhole gaps.
Then the larger screws can then be used to secure the top fans to the case and radThats how I've done it anyway
noticed this on the corsair site http://www.corsair.com/en/support/warranty/ "Corsair offers a 1 year, replacement-only warranty for refurbished or factory reconditioned PSUs, Cases and Cooling units." so they come with a year instead?
Edit: saw its now 1 year with OCUK, these are looking more tempting, worried about the amount of leaks people have had.. and the ribbed tubing looks a bit odd
Having to RMA my 2nd one now :/
Pump seems to just die randomly and then overheats and BSOD's![]()
Hi Greybeard, before now I'd never RMA'd anything so I really don't know how it works :/
Should this be RMA'd through you (Corsair direct) or not?
Yeah, it's a year now.
If that includes damaged parts like if it were to leak over my GPU and mobo and fry them both you'd pay for what? A new cooler a new motherboard of similar spec and a new graphics card of the same or new version? ie. If I were to have my old 460, you'd replace it with a 760?
But yeah, if that's what happens. I'll be buying a corsair H series cooler on Tuesday![]()
My H60 pump has started clicking rather loudly, I have tried the fixes around on the net to no success, should I RMA it to corsair or ocuk? :/
Sorry If missed this question. Basically, when a cooler leaked and it happens that some other hardware got damaged (assuming all steps has been done via Damage Claim process from Corsair, where the cooler was found guilty), the user will be compensated for all the parts that have been damaged in the means of check and not a part replacement. The amount will be based on the current market value of that given hardware. Using your example; your 460 will be roughly around $90-$120 at the moment. In this case, you'll get a check for the amount agree upon within that range.
Just a side note, all damaged parts that needs be compensated, will need to be turned in to Corsair so we can justify the check amount that needs to be processed.
At this point, let us handle the replacement for you. Before we do that, I wanted to ask a couple of things. You said that the pump kept dying, and I wanted to know if it's the whole unit including the fans or is it just the pump itself? If both the pump and fans, then It must be a power issue which is normally related to the molex connected to the PSU. Make sure that the connector is properly seated, otherwise, you'll lose power.
It's it more self evident, then please submit a ticket here, then once you have a ticket #, let me know what it is so I take care of the postage for you.
