Did you just recently purchase the cooler? Or something you have been using for quite some time now?
Hi, I'm buying a H100 this week, I keep reading about 'push/pull' fan configurations, can someone tell me what this means please?
I will be using the supplied fans to begin with.
It just means you add another pair of fans to the radiator, one set pushing air through the rad, the other pair pulling air.
Right, so the rad is sandwiched in between.
Have you done this? If you have what fans did you use? I can't imagine the stock ones will be up to much, i'm thinking about noise too obviously.
Looks like this:
H100 with 4 x Corsair SP120s in Push/Pull - Sucking in air from outside into case.
That's a 900D. The H100 is a temp stop-gap until I do a next big upgrade where I will go full custom loop.
Rear 140MM exhausting air from inside the case out the back
2 x 120 Upper Rad Fans pulling air in from the top of the case and pushing through the rad
2 x 120 Lower Rad Fans pulling air through the rad into the case
3 x 120 Case Front Fans pulling air in from the front of the case.
I want positive pressure inside the case to try keep dust out....mammoth task in a 900D though![]()
I use performance ones but I have a fan controller. Would be FAR too loud without a controller. So either PWM or Quiet Edition models might suit you better.
CPU temps for me under heavy load is 65-70 (IE synthetic stressing). About 57 for heavy games (BF4)
Brought it on the 19th July and it arrived about 1-2weeks later, something like that ( order number OC1643034)
It's been a while then. I think it'd be best to get it replaced via Corsair RMA. Go ahead and submit a ticket here
and we can take care of it from that point on.
The problem is corsair don't have a UK based rma centre so the the cost of sending these to the Netherlands? almost outways the purchase price which has put me off from day one from buying one anyway, my old AK 620 is still going strong after 2+ years
OcUK range of controllers is here:
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=2331&subid=189
