- 15 May 2012
- Louth, lincs
Was the card bought with the block on?? Are the fan headers visible on the card, can you plug the cooler/fans in to make sure its getting some power.
Also try your original psu cable, dont use the extensions, they could be faulty
Check all screws on the waterblock, dont overtighten, just nipped up.
Also try a temporary prop there is a definite bend unless you used a fish eye lens!! Mine bends too so not a big worry.
