Is this worth playing if you are not remotely interested in HP?
It's insane that I'm CPU limited to point of struggling to maintain 60fps, the 3900X isn't even that old. I've held on to CPUs for 5-6 years and still enjoyed good performance, wtf?
Time to get an Ryzen 7 5800X3D!![]()
I'm going intel next, AMD CPU's don't age well.
You should cap your frame rate to a few FPS below your monitors top spec. You don't really want Vsync doing anything, but G-sync stops working right at the top of the range.
In my case I can use 120 because my monitor does 144hz.
Should turn Vsync off in NVCP as well as in the game, let G-sync operate within the fps range.
Some people said to set the camera acceleration to 0 as well.
Beyond that switch off most of the extra stuff like motion blur or whatever if it exists, I think I only left Depth of Field on but that one is optional.
If you have RT on try it with RT off and see how your performance compares.
Definitely. I haven’t seen any of the films but I am loving the game, it’s superb.Is this worth playing if you are not remotely interested in HP?
I just bypass any ingame caps entirely and use RTSS exclusively for that. Just makes things easier as not all games employ frame cap the same way, some can introduce further latency for example or add stutter, whereas RTSS only adds a single frame of latency.
I suspect the same applies to FreeSync displays too.
How have you managed to get HDR working on the Ultrawide? It's greyed out for me and I can only do windowed fullscreen rather than true fullscreen.Just playing with HDR enabled, actually some nice quality HDR really have to say.
Also, I've unlocked the Raiden look from Mortal Kombat![]()
For this one, if I limit frames at RTSS to 60 and set Hogwarts uncapped, it uses more power than if I also limit Hogwarts to 60.
I think under the hood by not limiting Hogwarts it's rendering more frames and then RTSS is only allowing it to show 60.
Behaviour may differ by game, but this is certainly what I've been seeing.
Some minor tips for people:
- On the main gear selection screen there is an option to modify the appearance of gear, so you can stop looking like a clown
