I have not tried it since patch but first thing I thought was, probably made it better for <= 16GB RAM but worse for 32GB+.Patch has made game unplayable for me. Never had this amount of stuttering before.
Use the disillusionment spell for the chests.
The other night when I was playing, I accidentality found out that if it's night time and you approaching one of those chests you can open it. Was a bit surprised so when I saw another I just walked up to it and once again coudle open it. Guess it sleeping in the night if outside (in the castle time don't seem to matter, it always catches you).
Not had any problem with the new patch. Then again I did do a totally fresh install of my drivers so might have helped me there. Hopefully you can get it sorted and enjoy the game again without the stuttering !
twice ive had to defeat that bloody acromantula, those other spiders are buggers when they tunnel up behind you when your fighting others off
Never had any issues with performance locked at 60 FPS
Anyone find the patch seems to have broken RT again? I've turned it off for now its more trouble than its worth on the upside I'm back to 120fps+ again
Yes, apparently there are two versions of the game, The ones the 99% have and these perfect copies that exist elsewhere.
Then again I've never thought to lower the fps all the way down to 60fps. Could be worth a go although it's generally around that with everything maxed out and ray tracing with no DLSS.
Shame as this game would look stunning fully path traced.
