- 6 Sep 2016
I guess his measurement equipment can't detect those magical frequencies, and thereby your ears are far more sensitive than something which can measure again and again in the megahurtz range.
Is there a response graph for the GHz range vs a standard power lead?
I agree that RF filtering is good - that's why I add filtering to my amp and decouple too with small ceramic caps. However the question here is what is the result of comparing with a standard power cord?
emianalyst.wordpress.com
Instruments more separated
Hilarious that you think a cable can substantially alter the recording..
Of course the recording does not change.
What does change is reduced noise into audio components. When you lower the noise you increase the detail.
I've never once seen the response graph for a Kimber mains cable. I would be very interested to see one however.
I am repeating myself, but the RA Kimber Kables have an effect on the audio. The effect is less harshness in the sound, instruments are more separated, it's just better sound quality.
If we ever do that group HiFi meet, I'm happy for you to test my cables on your scope.
EDIT. I did find these measurements on twisted cables. So the Kimber Kables should be doing something very similar if not better due to the multiple twisted cores.
Effect of Cable Twisting on Radiated Emissions
It is common knowledge in electronic cable design that twisting wire pairs together is usually a good thing. However, the benefits of twisting and the degree to which twisting is valuable is less w…emianalyst.wordpress.com
)NickK, what voltage would that start to clamp?
See, this sounds just wishy washy nonsense.. sure you could argue the higher the SNR the more 'detail' you get, but that's just far too vague, the ability to resolve detail from a DAC is by far more a function of the design of the DAC vs the SNR.. I'd take a 3db increase in the noise floor (therefore lower SNR) with a more precise DAC.. it's very very very difficult to distinguish between a 120db SNR and a 117db SNR.. which is why I don't wholly subscribe to the holy grail of SNR.. I'd rather more precision and more importantly how dynamic a DAC is which is all measurable.Of course the recording does not change.
This is all snake oil because it's so badly misrepresented..
Networks are incredibly noisy, for starters they naturally create a massive amount of noise as they carry 250mhz (CAT 6) of digital signals, so have a very messy spectrum due to the complex harmonics.. The ethernet transformer/phy and all the filtering should take care of that, and certainly any modern power topology within a device would ensure that sensitive circuits are on a separate adequately filtered supply..
We make medical devices, some have sensitive measurements down to picoamps and ranging up to 5mhz, these are on the same PCBA as a computer module (x86, incredibly noisy) as well as 2 network switch ICs and 8 PHYs, not to mention all the RMII and SERDES lines for the highspeed switch ICs.. you'd imagine it would be impossible to measure complex signals that are a few picoamps on the same PCBA.. but it's not that hard.. You ensure as much isolation between power supply rails for each subsystem, you don't feed the same 3v3 to the network switch ICs as you do the ADCs for the measurement system and modern EMC best practices can be applied such that radiated emissions with housing do not become conducted noise within the measurement circuit.. we even use 'precision power supplies' for the most sensitive ICs...
The problem I have is that the claims are made to look like a product should universally be effective, but in reality it's really only going to apply if you have a badly designed susceptible device and ultimately that will be measurable..
And further to that, the biggest factor in the dynamics and overall presentation is the DAC and amplification sections, those are well downstream of any conducted immunity issues in any meaningfully modern design, and that's where the real quality starts and ends.. and 99% of these products can't and measurable don't affect those unless as mentioned someone has dropped the ball when designing them.
It's snake oil, they claim "zero-jitter memory buffer and galvanically-isolated inputs", not only is the 'isolation' part laughable since their PCBA look to have just slapped down a bog standard Ethernet (pulse) transformer which any equipment that wanted isolation would already have, but worse, they are then mis-representing it as a 'zero-jitter memory buffer'.. that's misleading and downright snake oil IMO, although I'm open to correction but I'll stick to my guns since 'jitter' is not a problem on ethernet, it's all buffered and transmission rates are far higher than the consumption rate, which means the presentation is absolutely nothing to do with any form of jitter..Indeed add to that the random impedance matching and reflections, in addition to noise. This is why it's vitally important to isolate for digital signals. After that the digital signal (as it's powered by a quiet side supply) is far far cleaner.
I don't think filters on are snake oil, but they're being used to patch the obvious flaw in the design and being sold as a solution to everything. Key for me is removing the issues of RF and oscillations caused by bad design (using an RF capable opamp without taking the precautions - leading to a harsh sound). In the end the average audio geek is simply going to follow the herd, attribute the fix to the device but not actually be able to measure the impact other than what is perceived via the speakers..
It's bad and needs to be called out, that £90 or several of those if you went mad sticking them in every orifice they fit in could fund a much better amp, dac, speakers, source, etc.. all things that measurably can improve the experience.
Awesome, good work!Ahh I was talking in general - isolation using a digital isolator (where you have Schmitt triggers etc) reduces noise.. but the signal going across it will still be subject to jitter still as you're quantifying it with the Schmitt triggers. Can't see a buffer in those images.
This was mine - clock + 1:3 fan board and i2c + i2s digital isolators PCB, my first ever PCB design. The additional circuitry is for a couple of ways to add a shunt supply:
I think I could have done a better job than their board![]()
iFi audio | British Hi-Fi Audio Technology Company
Discover iFi audio, a premium award-winning audio tech company dedicated to high-end music fidelity. Superior sound, designed in England for audiophiles.ifi-audio.com
Hmmmm.
The network cable is the least important cable. I use Amazon Basic Cat 7 as they have a very good outer braid on them, they can be purchased for around £5 on Amazon Warehouse. Using a good shielded network cable is good audio hygiene. That said I have never noticed an audio difference from a network cableYou even see that sort of behaviour for network cables. On Amazon, 24000 people have bought ugreen Cat8 cables and, reading the comments, it's clear that most of them think it will perform better than a Cat5e with their home router.
