Hi all. I have read this thread but am without doubt an LED newcomer.
In my lounge I have 8 spotlights at 50W each. They operate on a dimmer switch. This means when the dimmer is on max the lounge lighting draws 400W!
I also have 6 of them in my bedroom that operate on a standard switch, also 60W each. The bedroom I would like to change first as there is thick loft insulation above it which would be very difficult to move, so I am thinking LED lights don't get hot which could solve the issue more easily.
I also have 3 in my study which are also under a lot of loft insulation.
This appears to be the shape/size that I need but **** me £19 each (dimmable for lounge) is so high I wonder if the 'break even point' even exists financially. This is getting into the realms of 'I bought an expensive diesel for better MPG' where it can often turn out more expensive!
I need GU10.
http://www.energybulbs.co.uk/philip...gu10+led+-+very+warm+white+(40%B0)/1805903364
EDIT: Just noticed I have 50Q GU10 all over my house!!!! 28 total!
