E27 bulb.
My understanding is you'll need a transformer/s that will drive the total power consumption (W), or your LED lights lights will flash on and off.Guys,
I am after some LED countertop and Up Lighters for the kitchen.
Looking at these http://www.ledhut.co.uk/led-strip-l...arm-white-best-price-on-the-internet-467.html
Now I have 2 sets of counters with a space in the middle, 1 2.5metres long, the other 5metres long. Obviously I would like these all powered from a single transformer and controller for colour?
Also do you know if I use this controller:
http://www.ledhut.co.uk/led-strip-lights/rgb-rf-controller-with-colour-dial.html
A - Can it control them all
B - Does it keep the colour which was last set from switch on/off
Thanks!
So if you are going to install 3x 2.5 meters of LED lights at 36W each then you'll need a transformer/s that can supply 100W.
On your 2nd point - when you switch the lights off using your light switch you will lose the last setting. To retain the setting, you will need to turn the lights off using the colour controller off switch.
I have just installed undercounter LED's and have 2 transformers driving the two seperate cupboard runs.
The LED's you're looking at are going to be very bright (2700 lumens), I have the the 120 small LED's and they are plenty bright enough at 1800 lumens.
http://www.ledhut.co.uk/led-strip-l...arm-white-best-price-on-the-internet-455.html
Anyone ordered the SuperLEDTM GU10 LED bulbs from Amazon? I've ordered three in cool white for our wardrobe. Specs seem good with 460 lumens and 120 degree beam angle.
Installed these (on a push-to-break switch) if anyone's interested:
Looking for a half decent pair of dimmable LED Globe or Candle type bulbs, large screw (e-type?), 30-40w equivalent and good quality/very long life span preferably. Any suggestions?
They're for outside lights that are dimmed normally then go bright on PIR.
You might come unstuck, as LED lamps need a special 'Trailing Edge' dimmer, so your fitting might not work properly.
Here is a photo of my kitchen with the 4W cool white LEDs from the Ledhut.
The four bulbs in the foreground are LEDs and the ones towards the rear are halogens.
In my hallway upstairs I have got LEDs also but these are the warm white versions, which are somewhere between cool white and the halogens in colour.
After seeing how bright these 4W ones are, and looking back at the 2W ones in my study, I think that s 50W halogen would probably be equalled by a 3-3.5W LED.
Out of interest which ones did you actually buy.
http://www.ledhut.co.uk/gu10-smd-led-220-lumens-45-watts-equiv-best-internet-price.html
The cool white ones are in my kitchen.
The warm white ones are in my upstairs hallway.
I am yet to try the dimmable ones.
My study is using the 2W version of these:
http://www.amazon.co.uk/Philips-CorePro-CLEDS2WGU1030ND-GU10-2-35/dp/B00CHJECXI
Watch out though as the Philips ones are only rated to last 10000 hours (8-10 years) and other LED bulbs are rated to last double that.
