All
I have just bought some 5w GU10 LED bulbs.....
Was surprised how hot they get, then realised that they must have a transformer of some sort included.....is this right and do others get hot?
Thanks
I love them. The only drawback for me is that they aren't quite as bright as I'd like. Before the Hue bulbs I had 700+ lumen warm LEDs and the Hue's (rated at 600) are noticeably dimmer, though they are just about bright enough. Also be aware that when using colours the brightness goes way down.what do you think of the Hue?
tempted to get it set up in our place but its quite an investment.
All ready for Saturdays bedroom install. Downlights, LED bulbs, tails, chocbox and insulation support boxes
LED bulb 4.5 GU10 warm white - http://www.ledhut.co.uk/spot-lights/gu10-led-bulbs/new-4-5-watt-gu10-led-350-lumens.html
Sylvania Fire Rated Downlight Fixed GU10 Mains Brushed Steel - http://www.toolstation.com/shop/Lig...+Fire+Rated+Downlight+Fixed+GU10+Mains/p13444
Prysmian 6242Y Twin & Earth Cable 1.5mm² - http://www.screwfix.com/p/prysmian-6242y-twin-earth-cable-1-5mm-x-50m-grey/51381
Choc box / connection block - http://www.ebay.co.uk/itm/5-OR-10-X...pplies_Electrical_ET&var=&hash=item233624d8a8
Insulation Support Box Freestanding Flat Packed - http://www.fastlec.co.uk/click-gb400-insulation-support-box-freestanding-flat-packed#.VFFcIvmsXT9
why did you bother with the choc boxes mate, couldn't you have just made all your connections at the bulb screw terminals - that is what I have done with all of mine
