I bought some 'dimmable' LED bulbs from costco the other day. They're in my touch lamps, but when in they buzz a lot. Is this normal? Safe? Is dimmable in a touch lamp different to dimmable on a standard light switch?
Right guys, wondering if you could help, after some specific bulbs.
All 4000K colour
ES (E27) 300-400 Lumens, Candle/Narrow sphere shape
Any ideas where?
Candle lamps have traditionally only ever been for specific light fittings that wouldn't really look right with a 4000k lamp in. Are you sure you want a 4000k candle?
See if anything here takes your fancy
http://luxreview.com/article/2015/05/retro-lamps-10-of-the-best
Hi,
I recently ordered THESE, and installed them in the bedroom with a dimmer. Unbeknownst to me I needed a compatible dimmer switch, so when I installed them they emitted a loud buzz.
I have since installed one of THESE VARILIGHT DIMMER SWITCHES and the buzz is still there, despite this being the exact switch I supposedly need to eliminate the problem. Has anyone ever experienced such issue with LED bulbs?
Does anyone have these:
http://cpc.farnell.com/philips-lighting/mled6wcndlb22/6w-master-ledcandle-diamondspark/dp/LP08361
If so are they any good?
Looking to replace my front room bulbs and whilst these Philips are probably good I will try to find them atleast half the rrp as they are too expensive imo. If I can't I will go with something like these instead (solely based on price):
http://cpc.farnell.com/integral-led...6w-equivalent-40w-2700k-warm-white/dp/LP08090
Possibly a daft question, but I'm looking to buy a couple of replacement 8w fluorescent tubes for some under cabinet lights in my kitchen. Now admittedly, I'm judging this from a trip to B&Q, but it looks as if the existing lights might be a non-standard size, as they're 337mm in length by 12mm diameter. The lamps currently in place are Lytlec branded, the only other indentifier being the code 2700k printed on them.
Would this be a model number or a size code or something?
Thanks!
Your preferred bulbs are £6.29 here for a kickoff:
http://www.energybulbs.co.uk/philip...bAI8WGTP6JWm_4WURhr1PWUXfpSWzhypZpRoC5Trw_wcB
I've got a few Philips bulbs installed. No problems as of yet.
The 2700k is the colour temperature of the bulb: http://www.westinghouselighting.com/color-temperature.aspx
Is this anything close? http://www.lamps2udirect.com/fluorescent-tubes/t4-lytlec-8-watt-fluorescent-tube/67035
Hi
Recently ordered some bulbs from led hut, I've ordered from here in the past, so ordered again recently due to past good service. My order has got delayed somehow at there warehouse.
Anyway hopefully should get it sorted but thought I would check reviews of them and I was amazed at all the 1 star reviews, what's happened, have they gone downhill? They used to be mentioned on here a lot.
Any better places to order from.
Thanks
it would appear they have gone to the dogs.
