Where should on buy from then?
Avoid Diall. I bought 8 GU10's (3000k, 350lumen, 6.5w at £13 each) for my kitchen. One failed after about 9 months, B&Q wouldn't replace it even though they have a 12 month warranty and a claimed 10 year life, because they'd changed the spec from 6.5w 350lm to 6w 340lm so it wasn't "like for like"
Since then another 2 have failed....
Even if they are made by Osram, I'll certainly not buy those or for that matter any LED from B&Q again...
I remember somebody was after GLS-type lamps that weren't 2700/3000k for some reason, CPC have recently added these to their product range. No idea if they are any good but the specs fit the brief:
http://cpc.farnell.com/pro-elec/pel00220/lamp-5w-led-filament-e27-4000k/dp/LP09271
http://cpc.farnell.com/pro-elec/pel00228/lamp-8w-led-filament-e27-4000k/dp/LP09279
Redecorated my daughters room, standard dimmer switch with a LED bulb that is dimmable. Generic brands.
It works ok, but it flickers when on full, hums slightly when dim and seems to go from 0-100% with very little switch play.
Are they all like this? is it the switch or the bulb that is more likely to be the issue?
There's really no point in doing LED downlights by purchasing GU10 fittings and lamps now that it's 2016. Buy an integrated luminaire - the output will be much better as the temperature can be controlled and the LED doesn't have to be compromised to make it fit the form-factor of a halogen lamp.
Out of interest, which bulbs did you use for your car? I replaced some of mine and they're not very good.
Could you show me some examples please?
