Yeah, i saw It.Thats the c2 on rtings test for colour gradiant
Mine isn't good as that
I cant find the rtings test pic to try on mine, you got a link please?
So Is It Better than Mine i guess?some slightly visable banding in the green and grey ones only here, pretty much matches the pic rtings have though. 8.2 i would say is fair. Sony seem to have the best banding full stop.
It was this step:
Even though I'm wired and using a static IP, I couldn't get WOL to work.. I have an android app on my phone that will send WOL packets and that didn't work either, then I spotted the above and that instantly worked.. Stupid wording making it look like it's just 'Wi-Fi'..
Folks just a few questions...
1. is there a way to prevent those pop up messages to appear when starting the monitor?
2. I heard there is this LG companion app so that it turns your monitor off and on when pc starts, is there a guide how to set this up as I did try it once but was not succesful.
3. I used the settings given in one of the videos to prevent autodimming when changing screens, but I noticed this doesnt work when I have my laptop plugged in for some reason.. any ideas?
4. Forgive the incorrect terminology used. I was told that you cant turn the autodimming off but there is one autodimming function which can be disabled using the special remote, what are the differences between them?
5. Also when I leave the monitor for a little while it dims automatically, thats normal I guess?
How can you not. It's top of the pileWell, after using it in ultrawide for a few days my opinion has changed and loving it now.
Im clearly uneducated about this panel. How do you put it into UW?Well, after using it in ultrawide for a few days my opinion has changed and loving it now.
No probs. Like I said, A sticky on setting up the LG and other OLEDS would be handy in this sub forum100% agreed. This is a great panel!
I need to set up that companion app, thanks for re-linking the site for it Greebo.
Yes thank you Greebo for the repost.
Can I just check though there are two videos and each is recommending different settings for the contrast colour etc. Which should be followed?
