Caporegime
- 13 May 2003
- Warwickshire
Richer Sounds are now doing a straight £100 off instead of the buds offer in case not already mentioned.
That’s the one I would consider as no fees:
https://www.americanexpress.com/uk/credit-cards/platinum-cashback-everyday-credit-card/
Your link has a £25 a year fee. I already have a credit card with a fee I use for shopping etc which pays for its self and leaves some cashback each month, don’t need another one with a fee, just need it for cashback offers and big purchases![]()
I think he asked for an adapter for a monitor mount - in this case we will need one, as most monitor arms have vesa 75x75 and 100x100, while 42c2 has vesa 200x300. You need adapter like this:
https://www.amazon.co.uk/Part-King®-Mount-Adaptor-converts-Black/dp/B071K6STY2/ref=sr_1_6?crid=2GAJQMVR1B9EF&keywords=vesa+75+adapter&qid=1647700434&sprefix=vesa+75+adapter,aps,43&sr=8-6
Do we actually know how wide the TV is, left stand foot to right stand foot?
I know the TV is 932mm wide overall, but each foot looks about 100mm in, from each side?
Free money always comes at a cost!
They both seem like great choices so I don’t think either way you will lose out. The AW QD option has a better warranty though.Ah thanks, thats the one. Still undecided on this, would be great for someone to run this side by side versus the Alienware QD Aw monitor, once they are both out.
No real brightness difference between C2 and C1 but a tiny bit he says... better to wait for real comparisons though
At first I thought about the stand is not solid but if you see carefully at how this type of stand is done, it could be solid:So a bit of a dilemma, so caught up in the excitement I didn’t think to check the size of the stand, it looks like stand will overhang my TV stand by around 5cm each side, depth is fine. Is this likely to be an issue, stand looks solid so not sure it is?
Each time I'm on the verge to kinda give up, I easily get convinced to get the 42C2... I hate mysef. But yeah, OLED pixels are sharper so imagine the ppi on the 42C2.Its important to remember when you see these comparison videos like the one I posted above, take it with salt since its much different in actual person.
Cameras no matter how good can't capture what the eye sees, I rely more on the verbal commentary, he did mention the C2 was tad brighter
and more sharper detailed then what you see on the camera so I kinda go with that since he is in person. Half these Ytubers don't even own high end
cameras and YT itself compressed the video cutting out detail also.
Id wait for Vincent or Phil from hdtv to do better comparisons, rely on their audio commentary also.
I think Vincent and techradar early thoughts are spot on still, there probably won't be any major difference between C1 and C2, not unless you got the C2 55"+ to see that extra Evo brightness.
Still the LG C2 42 is the best 42" currently on the market, well until QD-OLED or better 42" comes along.
