If you press Home on the remote and Art Gallery, can you change it from there? Don't use it much myself so not 100% sureNext question. How do I change the art gallery choice and wallpaper settings. Id like to change them but can't work out how?!
Thanks to LG Sweden I say - Here we have the standard guarantee for 3 years, and - YES- that includes any burn in-out whatsoever!
So for once it's good to be a Swede
oh and one can extend the guarantee to 5 years, and for pretty cheap, directly via LG!
I know this is 100 percent true, as I talked /mailed them about it several times. So no need at all over here, to buy any extra guarantee!
Yeah really good on them over here. I actually said this to ppl here in Sweden; that was about to buy extra expensive guarantee from the store etc. Happy to see they do what We think should be standard everywhere!Yep you can change it from there, add in a bunch of new scenes to the mix.
Dang that is very niceOnly 5 years for the top range models in UK as standard direct, even then not sure about burn in, otherwise 1 year direct.
@R3X LG started crushing black since C1 to avoid the noise about chrominance overshoot so here you are. Go 52 or 53 on brightness for the first 200hrs. Then drop done to 51. That should get you close to ideal.
Cheers was not aware of that, I was left wondering my CX didn't ever feel that bad.
That is what I have done its gone well over 200 hours usage, so dropped back down to 50, tried 51 also but its still crushing quite badly its almost unwatchable during dark scenes. I was hoping once it was used in more it would improve but not seen any.
What's your gamma set to? 2.4/bt.1886 is ideal for dark room viewing. For daytime and/or room with lights on, I'd run 2.2
If you're at 2.2 and brightness around 51/52 yet still having issue, you need a calibration.
Make sure you got power saving/eco stuff disabled as well. Not sure with 2 series but previously, there were two places where you had to disable them.
This is a bit of an ask, but only if you get a chance since you have the 42C2
Can you run this video in a pitch black room at night :-
https://www.avsforum.com/attachments/nearblack16-27-zip.1661825/
If you can see any black boxes on the top left corner, even if slightly there or not or let me know which ones you can see at least please
Its a shadow level detail video someone created on AVS community here:
LG OLEDs - how to enhance near black detail
www.avsforum.com
Cheers for testing it, from that pic it looks excellent do you think it was the top left 4 boxes that you could not see like it is in your picture?
Do you have black level @ 50 also?
Yes. To my eyes the top 4 left boxes wasn't visible and yes black level set to 50![]()
For those using C2 for productivity work - for how long a day you using it for work, and how you finding it after some weeks of ownership? Any buyers remorse and wanting to go back to "traditional" monitor, or still happy? Assume you keep thinks like Slack/Discord minimized while you work?
