You'd have thought so but I'm guessing that i9 is a power hungry beast.
Thanks again everyone.
I'll test the psu tomorrow with a psu tester. I'll update the thread after this.
165W stock... 500W total system consumption with no GPU usage when overclocked?
Umm...
A bios updates does not kill a PSU but could kill a motherboardprobably but I don't think you should be categorically saying that until the psu has been ruled out. op rma's motherboard - tested and found to be fine op gets a testing fee and return shipping charge and then has to rma/replace the psu. no need to make a poop situation pooper
1 quick question that might help identify if it is the board or psu - is the power button on the board illuminated when the psu is turned on? you can do the paperclip trick, only takes 2 seconds really. least you'll know if there's any life in the psu before going in with the tester
Untill you get a PSU in the machine that works its hard to say if anything is damaged, but corsair isn't a bad make so should have protected everything else. Never skimp on the PSU I would have said 1000W minimum and a decent brand. iam not saying corsair isn't, just saying 750w is not enough.
just cause the rev counter says 9000rpm then red line, don't mean you drive on 9000rpm. give yourself some head room even if not overclocking. cause to have a chip like that a standard clocks is like going to the pub to drink water.
And if circuit breaker tripped when the PC restarted its for sure a power issue and PSU dead.
Not disputing that, but you ever heard of coincidence? Ruling out the psu is relatively easy so I suggest he does that first.A bios updates does not kill a PSU but could kill a motherboard
the whole electric power was cut from the wall socket. I had to go
The OP has stated since your post the mains fuse tripped at the same time PC restarted. so PSU is favourite to have failed.
Were you using the mains lead that came with the PSU, have you changed the fuse, or tried another IEC C13 cable?
Also are you using a multi way extension, if so takr that out of the loop, and see how it gets on.
The motherboard supports dual bios but i did not have a backupIf the power went down during the update the board is toast. Do you have a dual BIOS OP? That's all that might save you now.
seasonic is still a good brand, my mistake on brand, just 750w is not enough mate.
