What power supply is It?
Mine is Seasonic Prime Titanium 750W
My friend's is Corsair 500W
Might be worth trying just to see if the system will boot with a minimal config.
What's a minimal configuration?
I hope you didn't tell them the electricity cut out. I'm not suggesting you lie but being overly truthful isn't always the best policy!I've just placed a support ticket with the retailer.
Will update the thread when i have more news.
Thanks everyone.
Also, and maybe already covered but have you plugged something like a table lamp into the socket just to make sure it's actually working?
Ok cool. Just wanted to check.I have not mentioned the power surge.
I tried the psu in different working sockets
The 165W TDP on the i9's is... optimistic... at stock. 300W could be hit easily even with just MCT which might be enabled automatically in the bios.
The 1080ti could easily draw another 250W-300W depending on model.
Those two components alone are getting on the high side for that PSU imho. Add in all the other components, and I would def want a larger PSU.
Why does the Seasonic online power calculator recommends 650W with all the
components?
