Kindai is lending me his GTR
What a guy!![]()
I guess you two don't know each other in real life? If so, even more of a guy!![]()
How generous![]()
considered a car swap but insurance implications would be a pain so I'm probably nipping over to his tmoz for him to show me round the car and get to know them a bit better
Woo! Big drop in the insurance.
I felt so with my M5, these are absoloutely epic though but some of the servicing costs and other bits put me off wish I'd had the balls to try one
Edit : like Will said
Right! New tyres done!
Thoughts? Well I gave them 10 miles or so scrub the worst of the release agents off before getting a bit frisky for 20 more miles. This was coming off my pzeros with 1.8mm of tread left all around.
So far, incredibly impressed. A definite improvement in all aspects, grip is incredible, theres a bit of road/hill I could easily turn into and spin the tyres up on pzeros when flooring it, when I did this with the MPS4S they hooked up instantly and launched me up the road!
Cornering and feedback is exactly as expected, though until they are scrubbed in for 100 or so miles I won't be pushing my luck there.
Slightly, but only marginally, noisier then the pzeros.
Cost for all 4, £816 fitted.
Same when I moved from my 1.6mm Pzero to the MPSS on the M5. The difference was just astounding but then some of that has to be down to the fact the PZs were so low on tread. Oddly, I find the MPSS quieter, my Android Decibel Meter app confirms.![]()
Not just tread but also effect of fresh rubber. As tyres age the rubber becomes less soft/grippy.
But thats not taking away from how amazing MPSS are, I change out my Pzero with 3-4mm on rear and 5-6mm on front, the difference it made was incredible, particular in cold/wet conditions moving to MPSS.
I am hoping to make the same purchase this week as 295/35/20 PS4s just came into stock at Blackcircles, so am gonna go with 285/35/20 in the front and a 295/35/20 in the back.![]()
Do you want me to get you a quote from my guy Gibbo? He was 250quid cheaper than blackcircles.
Kindai, I don't suppose you could check for me?(not sure if PS4 are in this size yet)
2 x fronts: 265/35R20 in PS4 or MPSS.
Thanks
PS4S, sorry....![]()
No problem, hes going to get back to me first thing tomorrow with all the prices.
The only one he thinks there may be an issue with is the N1 specs Gibbo asked for.
