fish oil burps are gah!
Thanks for all the advice Jeffstar. Much appreciated. I've booked myself in for a gym tour, followed by an induction next weekJeffstar said:Snip
I was a sales advisor, and I've never really been much of a sporty person.fallbayuk said:shifty_uk, what did you do in your old job?? Do you play sport? You're a lucky bugger to have a physique like that without even going to a gym!
Although I haven't used a gym or done any weight training, I do exercise at home. Using as you say, bodyweight exercises etc.Linoge said:If you've not used a gym why do you call it 'progress', when it's not really a result of any direct weight lifting?
Have you been doing bodyweight exercises like pressups, chinups, etc?
megatron said:Id suggest doing dips before triceps and possibly before benchpress (but some may have issues with their bench numbers not being as good as poss). Reason is its a compound movement and I believe compound should be done first then isolation (like triceps). With dips u are lifting your own bodyweight which is greater than your bench so, whichever is the most taxing Id do first.
U beat my bench ( I suck at it, and avoided it for a long time due to shoulder problems), but I squat more. I dont know if I have disproportionally stronger legs than the rest of me, maybe.
I did some deadlifts this week, never really worked them into my rountine before. I use an opposite grip (palms facing in opposite directions), then drag the bar close to the leg (touching really). I think the time u got to be weary is if ** fatigued or the weight is difficult, that u keep abs flexed.
Bench Press is also a compound movement. I'd say it's also a more taxing exercise than dips. Yes dips are usually heavier using bodyweight but then so are press-ups, hardly a taxing exercise.megatron said:Id suggest doing dips before triceps and possibly before benchpress (but some may have issues with their bench numbers not being as good as poss). Reason is its a compound movement and I believe compound should be done first then isolation (like triceps). With dips u are lifting your own bodyweight which is greater than your bench so, whichever is the most taxing Id do first.
Heaven Can Wait said:Why would you do dips and bench press in the same workout?
Makes very little sense to me.
SK07 said:Why not? explain that.
dafloppyone said:fish oil burps are gah!
Heaven Can Wait said:SK07, not really much point changing your weight amounts, doing 50 reps with 40k wont help at all.
Put some more weight on your deadlift, it wont do any damage, squatting 110k should put your deadlift to around 140-150, so go to maybe 120.
You might want to change from chest + biceps and back + triceps to chest + tri's and back and bi's, the main reason being that every chest exercise you do will involve your triceps.
U posted your routine previously, are u going to change it now? What regime are u following?SK07 said:im changing it about in another week and a half anyway which makes up my 8 weeks of it.
SK07 said:I'll stick it up but I just don't want to do it one day and hear something pop or crack.
Well what you've said I've noted cheers im changing it about in another week and a half anyway which makes up my 8 weeks of it.
5kg is £32 or you can get 10kg from MP for £62 including delivery if you use the pricematcher to it's full potential.Ultra_Extreme said:oh btw, whats up with the price of unbranded whey on Myprotein? Earlier ChongWarrior was advocating its massive savings yet a 5k tub is like £50, i can get Optimum Nutrition 100%GS for that price and it tastes a lot better and has a better balance of components.
Ultra_Extreme said:You said your form was spot on, if it is then nothing should go 'pop' or 'crack'. The only danger to lifting heavy is poor form, allowing your back to go out of position for example.
Your bench press numbers are impressive for someone who hasnt trained long. I cant do 85 for 10 let alone 3 sets of it, in fact i dont know anyone that i think could even though i know a few 140+ benchers.
megatron said:U posted your routine previously, are u going to change it now? What regime are u following?
Personally I do my own routine based around compound exercises but try to mix it up a little so my body doesnt get too used to 1 thing.
SK07 said:I've been doing that routine for about a month. What I was going to do is the exact same program but for 1 month, cut the weight in half, for example take what I bench down to say 40KG and do a lot more reps to help strengthen the tendons and the small parts pretty much etc. What do you all think?
Ultra_Extreme said:There is no evidence that i have read to suggest that high rep light weight will help 'strengthen' things like tendons etc. What strengthens the body is stressing it so that it becomes damaged and must repair itself. Whats important is your rest and nutrition in between heavy weight sessions. Focus on this
