- 2 Apr 2007
- North Shields
I doubt that will work boff in but there is no harm in trying!
Latest version of OCZ's Toolbox can now update the firmware even if your OS is resident on the drive.
I wouldn't recommend you do this. Running the update tool from within Linux (Partition Magic) is much safer than from within Windows.
^^^ link to that toolbox, please![]()
Not aware that anyone has yet had a "real" problem from updating the firmware using the latest version of the Toolbox! I certainly have not. Decent sized thread in the OCZ forums and not a problem reported yet. Even if I did, I always take a backup of the drive using Acronis True Image.
I see your point mikeo but it's like that Asus tool that can update your BIOS whilst Windows is running... If it work's then great but should it go wrong then your in serious trouble. Performing a firmware update on a live OS drive is a bad idea. It might work but as many of the other guys will say it's a chance you take. Besides I quite like the Geek element of using Linux to do it![]()
Was rather easy and only took seconds. Much safer doing it within Parted Magic as Bunyan and DragonQ will confirm (good bunch of lads)
There you go.
http://www.ocztechnology.com/ssd_tools/OCZ_Vertex_2,_Vertex_LE,_Agility_2/
Just backup your drive first... just in case.
, my new(today) Vertex 2E is ver1.28 firmware, so will update when I get the chance.It'll work with those drivers if you use XP SP3 compatibility mode. Useful for secure erasing a drive when you have those drivers but, as others have indicated, using Parted Magic for the firmware update is safer. I have a complete Parted Magic USB stick ISO with the firmware updater and instructions here if you want to try this method. Just extract it to a blank FAT32 USB stick and boot from it. You might want to print or jot down the instructions first.Unfortunately, according to OCZ "This OCZ Toolbox does not work with Intel RST 10 series drivers" so it looks as if it will have to be 'Parted Magic' after all.![]()
Yes.Sorted, was really easy and quick, now on version 1.32
Is it normal...... for the writes to be faster than the reads at the first part of the bench ??
I never update firmware usually having seen engineers brick customers print servers and printers through updating firmware (I work for Hp), however the 1.32 release for these Vertex drives is a big update with loads of fixes and so I gave inWas rather easy and only took seconds. Much safer doing it within Parted Magic as Bunyan and DragonQ will confirm (good bunch of lads)
