but then again none of the methods are point and click
Ahh! you are flashing the wrong drive!!! The drive should be labled SDA. Have a look i think you will be able to spot your error
*Edit i actually may be wrong. Have another look anyhow.
Successfully upgraded from 1.27 to 1.32 over the weekend using Parted Magic and the flashing tool. It's a little nerve wrecking mind knowing that if something goes wrong you've got an expensive paper weight
Hi Bunyan,
I have a double checked and I am trying to flash the correct drive and on my pc it is labeled as \dev\sdc
I will contact OCZ and see what they recommend.
Thanks for your help.
Bashy.
