hello.. does anyone know if the external GuruClock display unit thingy from the Abit AA8 duramax/3rd eye boards will connect and work with the IP35pro/xe ???? cheers
even with USB support set to "by BIOS"?BIOS 17 ( the latest ) doesn't support usb keyboards when you hit the " Del " button to enter the bios, you have to plug in an old PS/2 type..
that's a CPU-Z problem though.I'm going to revert back to an older BIOS as the new one reports my cpu voltage ( E8400 ) as 1.080 in CPU-Z yet it was bang on the mark with bios 16.
My reading is that:
a) it only happens when RAID is enabled
b) it still works but is just very sensitive to timing of the keypress
well, I've read that some people are still able to get into it even on 17 with RAID enabled ...I have raid enabled, and I couldn't get it into the bios even if I hammered at my del key like a looney
Obviously A, cancels out B![]()
it's the CPU fsb termination voltage - higher voltage may allow for higher CPU fsb. You shouldn't have to go daft with it on an IP35 Pro though.Just a quicky BUFF, I've tryed searching through the thread but to no avail.. what does this CPU VTT do ? and what should be its max setting ? Thanks![]()
well, I've read that some people are still able to get into it even on 17 with RAID enabled ...![]()
As I don't run RAID (or indeed BIOS17) it's not a problem that I have 1st hand experience of.
do you have USB support "by BIOS?"
