Intel says HD2500 for 3450
http://ark.intel.com/products/65511/Intel-Core-i5-3450-Processor-(6M-Cache-up-to-3_50-GHz)
The list of boards is here - http://event.asus.com/2011/mb/PCIe3_Ready/ - yours supported it from BIOS version 2001.
Theres no way a Sandybridge-E will fit, its a completely different socket type.
The only real reason to get a 3770K for me is so that I'm not stuck with a 3570K wishing I had the top model
Have you seen any benchmarks which I can use to con myself into justifying a 3770K?![]()
but anything that results in temperature rise is never good for reliability
Absolutely THIS^^
Can't get the 3570K because I'll wish I had the 3770K instead.
Can't get the 3770K because I'll wish I had saved the money because there's no real difference in any task I'll ask of it.
The solution : Justify to myself that the 3770K is the best choice.
So I just need to cherry pick benchmarks that show the 3770K better than the 3570K.... anyone?
Because its the latest tech!. Most people just want the latest every other year and be done with it. Dont care if it is £30 more, I spent that on a chinese last night (Twas nice too!).
It's just progress!, And i can get rid of that "Maybe i should have" feeling for the next year or two, instead of saving a very few pounds. Anything over 4.5 which i hope for 24/7 will be pretty pointless in the real world anyway.
Just my opinion.
I was also concerned about the "Maybe i should have" feeling, if I'd have gone IB or SB. Spending more on an IB setup might have left me with that feeling, just as much as going for SB. If I had spent more on IB and got, say 4,4Ghz @ reasonable temps, I think I would have been thinking "maybe I should have saved some money and bought the alternative which would almost certainly be running cooler. I think that the lack of significant performance gap between IB and SB makes the decision very difficult, unless you just want the latest thing.
IB pumps out less heat than SB,
And from the point of view of heating your room it still pumps out less heat than SB - every review has shown IB uses less power whether it's at stock or overclocked. The only reason the temperature if higher is because the chip is less efficient at getting the heat away.In total, yes, but at a fair overclock the CPU temperature itself is higher.
So it will be interesting to see what OCUK come up with in Over-clocked Bundles. from what I have seen the heat isn't too bad up to 4.5GHz but then rises steeply.
