**Official MikroTik Hardware **
BTH is back.
What's new in 7.12rc5 (2023-Nov-02 15:17):
*) bth - added "Back To Home" VPN service for ARM, ARM64, and TILE devices;
*) console - display "End-User License Agreement" prompt after configuration reset;
*) ethernet - fixed default "advertise" property for CRS310-8G+2S+ device (introduced in v7.12beta3);
*) sfp - fixed 1Gbps advertise for L009 devices (introduced in v7.12beta3);
*) sfp - fixed 1Gbps advertise using SFP+ or SFP28 modules in SFP interface (introduced in v7.12beta3);
*) sfp - improved system stability with certain modules for 98DX224S, 98DX226S, 98DX3236, 98DX8216 and 98DX8208 switch chips;
Notice - SFP/QSFP functionality has been refactored for consistent behavior and better scalability. Now, compliance with SFP/SFP+/QSFP MSA standard is mandatory. This may cause issues with SFP/QSFP modules that are not fully compliant. All current MikroTik modules abide this standard.
What's new in 7.12 (2023-Nov-09 09:45):
!) ethernet - changed "advertise" and "speed" arguments, and removed "half-duplex" setting under "/interface ethernet" menu;
!) health - removed "temperature" health entry from boards, where it was the same as "sfp-temperature";
!) sfp - convert configuration to support new link modes for SFP and QSFP type of interfaces;
*) api - fixed fetching objects with warning option from REST API;
*) bfd - fixed sessions when setting VRF;
*) bfd - improved system stability;
*) bgp - fixed "atomic-aggregate" always set in output;
*) bgp - fixed "input.filter-chain" argument selection in VPN configuration;
*) bgp - fixed local and remote port settings for BGP connections;
*) bgp - fixed typos and missing spaces in log messages;
*) bgp - implemented IGP metric sending in BGP messages;
*) bgp - improved logging;
*) bgp - increase "hold-time" limit to 65000;
*) bluetooth - added basic support for connecting to BLE peripheral devices;
*) bluetooth - use "g" units when decoding MikroTik beacon acceleration on peripheral devices menu;
*) bridge - fixed fast-path forwarding with HW offloaded vlan-filtering (introduced in v7.11);
*) bridge - fixed untagged VLAN entry disable;
*) bridge - fixed vlan-filtering stability with HW and non-HW offloaded ports (introduced in v7.10);
*) bridge - improved system stability;
*) bridge - improved vlan-filtering bridge stability with CAPsMAN (introduced in v7.11);
*) calea - improved system stability when trying to add rules without the CALEA package;
*) certificate - allow to get and maintain Let's Encrypt certificate in IPv6 environment;
*) certificate - allow to remove issued certificates when CRL is not used;
*) certificate - fixed "subject-alt-name" duplicating itself when SCEP is used;
*) certificate - fixed certificate auto renewal via SCEP;
*) certificate - improved certificate validation logging error messages;
*) certificate - log CRL HTTP errors under the "error" logging topic;
*) chr - iavf updated driver to 4.9.1 version;
*) chr - increased OVA default RAM amount from 160MB to 256MB;
*) console - added ":jobname" command;
*) console - added "as-string" and "as-string-value" properties for "get" command;
*) console - added "terminal/ask" command;
*) console - added "transform" property for ":convert" command;
*) console - export required properties with default values;
*) console - fixed scheduler "on-event" script highlighting when editing;
*) console - improved ":totime" and ":tonum" commands and added ":tonsec" command for time value manipulation;
*) console - improved multi-argument property parsing into array;
*) console - improved randomness for ":rndstr" and ":rndnum" commands;
*) console - improved stability and responsiveness;
*) console - improved stability when editing long scripts;
*) console - improved stability when using "special-login";
*) console - improved system stability through RoMON session;
*) console - improved system stability when using autocomplete;
*) console - improved system stability;
*) console - restrict permissions to "read,write,reboot,ftp,romon,test" for scripts executed by DHCP, Hotspot, PPP and Traffic-Monitor services;
*) console - show full date and time in scheduler "next-run" property;
*) dhcp - fixed DHCP server and relay related response delays;
*) email - rename "address" property to "server";
*) ethernet - added "supported" and "sfp-supported" values for "monitor" command;
*) firewall - added "ein-snat" and "ein-dnat" connection NAT state matchers for filter and mangle rules;
*) flash - show more accurate "total-hdd-space" resource property;
*) gps - expose GPS port for Quectel EM12-G (vendor-id="0x2c7c", device-id="0x0512");
*) ike1 - fixed invalid key length on phase1 negotiation;
*) ike1 - log an error when non-RSA keys are being used;
*) ike2 - improved rekey collision handling;
*) interface - added "macvlan" interface support;
*) iot - fixed an issue where applying a script to GPIO pin caused GPIO to stop working;
*) iot - fixed behavior where GPIO output state would change on boot;
*) ipsec - fixed Diffie-Hellman public value encoding size;
*) ipsec - fixed IPSec policy when using modp3072;
*) ipsec - fixed minor typo in logs;
*) ipsec - reduce disk writes when started without active configuration;
*) ipv6 - fixed IPv6 RA delay time from 5s to 500ms according to RFC;
*) ipv6 - send RA and RA deprecate messages out three times instead of just once;
*) l3hw - fixed IPv6 route suppression;
*) l3hw - improved system stability during IPv6 route offloading;
*) l3hw - prioritize local IP addresses over the respective /32 and /128 routes;
*) led - fixed "interface-status" configuration for virtual interfaces;
*) led - fixed 5G modem mobile network category LED colours;
*) leds - added "dark-mode" functionality for RBwAPG-5HacD2HnD;
*) leds - added "wireless-status" and "wireless-signal-strength" configuration types for wifiwave2 interfaces;
*) log - improved logging for user actions;
*) lora - added LNS protocol support;
*) lte - added at-chat support and increased wait time on modem at-chat for Dell DW5821e, DW5821e-eSIM, DW5829e and DW5829e-eSIM;
*) lte - added SINR reporting for FG621-EA modem;
*) lte - changed R11e-LTE ARP behavior to NoArp;
*) lte - fixed 5G data-class reporting for Chateau 5G;
*) lte - fixed APN authentification in multi APN setup for R11e-LTE6;
*) lte - fixed FG621-EA possible timeouts during firmware upgrade;
*) lte - fixed IPv6 prefix for MBIM modems in multi-apn setup when IPv6 APN used as not first APN;
*) lte - fixed RSSI for FG621-EA modem to show the correct value;
*) lte - fixed Sierra modem detection for modems with vendor-specific USB descriptors;
*) lte - fixed Sierra modem initialization;
*) lte - fixed startup race condition when SIM card is in "up" slot for LtAP mini;
*) lte - fixed sub-interface auto-removal in multiple APN setups;
*) lte - show correct data class when connected to 5G SA network;
*) lte - use more compact logging messages;
*) modbus - added additional security settings for Modbus TCP;
*) mpls - added option to match and set MPLS EXP with bridge and mangle rules;
*) mpls - fixed "propagate-ttl=no" setting;
*) mpls - improved FastPath next-hop selection hash algorithm;
*) mqtt - added on-message feature for subscribed topics;
*) mqtt - added parallel-scripts-limit parameter to set maximum allowed number of scripts executed at the same time;
*) mqtt - added wildcard topic subscription support;
*) netinstall - added option to discard branding package;
*) netinstall - display package filename in GUI Description column if package description is not specified;
*) netinstall-cli - added empty configuration option "-e";
*) netinstall-cli - added option to discard branding package;
*) netinstall-cli - allow ".rsc" script filenames;
*) netinstall-cli - prioritise interface option over address option;
*) netinstall-cli - updated configuration option description;
*) netwatch - decreased "thr-tcp-conn-time" maximum limit to 30 seconds;
*) ospf - fixed adding ECMP routes;
*) ospf - fixed BFD on virtual-link with configured VRF;
*) ospf - fixed OSPFv3 authentication header length calculation;
*) ospf - fixed OSPFv3 not working with NSSA areas;
*) ospf - fixed parsing of opaque LSAs used by TE;
*) ospf - fixed translated NSSA routes not showing in backbone;
*) ovpn - added "tls-auth" option support for imported .ovpn profiles;
*) ovpn - improved system stability;
*) pimsm - fixed BSR update process;
*) pimsm - fixed UIB update process;
*) pimsm - improved system stability;
*) poe-out - driver optimization for AF/AT controlled boards;
*) poe-out - fixed rare CRS328 poe-out menu and poe-out port config loss after reboot;
*) poe-out - improved "auto" mode for devices with single PoE-out port;
*) poe-out - removed "auto" mode support for L009 devices;
*) port - add support for Huawei MS237h-517;
*) port - expose NMEA/DIAG ports for Dell DW5821e and DW5821e-eSIM;
*) qsfp - added 50Gbps rate support for QSFP28 interfaces;
*) qsfp - fixed incorrect QSFP temperature readings in negative temperature;
*) qsfp - improved auto link detection for AOC cables;
*) qsfp - use sub-interface configuration for establishing link (for 40Gbps and 100Gbps links, all sub-interfaces must be enabled);
*) quickset - fixed "LAN" interface list members if configuration does not contain bridge;
*) rip - added BFD support;
*) rip - fixed session not working in VRF;
*) route - added "single-process" configuration setting, enabled by default on devices with 64MB or less RAM memory;
*) route - added "suppress-hw-offload" setting for IPv6 routes;
*) route - fixed gateway after link restart;
*) route - removed deprecated "received-from" property;
*) route - reverse community "delete" and "filter" command behavior;
*) routerboard - added "reset-button" support for RB800, RB1100 and RB1100AHx2 devices;
*) routerboard - fixed "reset-button" support for wAP ac and wAP R ac devices;
*) sfp - added 5Gbps rate for SFP+ interface on 98DX224S, 98DX226S, and 98DX3236 switch chips;
*) sfp - fixed missing "rx-power" monitor with certain modules (introduced in v7.10);
*) sfp - fixed occasional bad EEPROM data reading for L009 devices;
*) sfp - improved interface stability for SFP and QSFP types of interfaces;
*) snmp - changed "mtxrGaugeValue" type to integer;
*) ssh - added support for user ed25519 public keys;
*) ssh - allow to specify key owner on import;
*) ssh - fixed SSH tunnel performance (introduced in v7.10);
*) ssh - improved connection stability when pasting large chunks of text into console;
*) supout - added interface list members section;
*) supout - added LLDP power to supout.rif;
*) supout - fixed BFD section;
*) switch - improved resource allocation for 98DX224S, 98DX226S, and 98DX3236 switch chips;
*) switch - improved switch chip stability for CCR2004-16g-2s+ devices;
*) system - fixed process multithreading (introduced in v7.9);
*) system - improved system stability during booting for L009 devices;
*) system - improved system stability when MD5 checksums are used;
*) tftp - fixed empty file name matching;
*) tile - improved system stability when using queues;
*) traffic-generator - added "priority" property for "inject" command;
*) traffic-generator - fixed traffic-generator on CHR and x86;
*) usb - added support for RTL8153 USB ethernet on ARM, ARM64 and x86;
*) vrf - limit maximum VRFs to 1024;
*) vxlan - improved system stability for Tile devices;
*) webfig - fixed "Days" property configuration change under "IP/Firewall" menu;
*) webfig - fixed timezone for interface "Last Link Down/Up Time";
*) webfig - improved Webfig performance and responsiveness;
*) webfig - try to re-establish connection after disconnect;
*) wifiwave2 - added an alternative QoS priority assignment mechanism based on IP DSCP;
*) wifiwave2 - added comment property for registration-table;
*) wifiwave2 - added station-bridge interface mode;
*) wifiwave2 - correctly add interface to specified "datapath.interface-list";
*) wifiwave2 - do not show default "l2mtu" on compact export;
*) wifiwave2 - enable changing interface MTU and L2MTU;
*) wifiwave2 - fixed malformed Interworking packet elements;
*) wifiwave2 - fixed PTK renewal for interfaces in station mode;
*) wifiwave2 - fixed re-connection failures for 802.11ax interfaces in station mode;
*) wifiwave2 - fixed sniffer command not receiving any QoS null function frames when using 802.11ax radios;
*) wifiwave2 - fixed untagged VLAN 1 entry when using "vlan-id" setting together with vlan-filtering bridge;
*) wifiwave2 - fixed warning on CAP devices when radar detected;
*) wifiwave2 - implemented an option to transmit IP multicast packets as unicasts;
*) wifiwave2 - improved compliance with regulatory requirements;
*) wifiwave2 - limit L2MTU to 1560 until a fix is available for a bug causing interfaces to fail transmitting larger frames than that;
*) wifiwave2 - list APs with a higher maximum data rate as more preferable roaming candidates;
*) wifiwave2 - log more information regarding authentication failures;
*) wifiwave2 - make 4-way handshake procedure more robust when acting as supplicant (client);
*) wifiwave2 - use CAPsMAN's "datapath.vlan-id" on CAP for bridge port "pvid";
*) winbox - added "Addresses" property under "Routing/BFD/Configuration" menu;
*) winbox - added "BUS" property for USB Power Reset button for LtAP-2HnD and CCR1072;
*) winbox - added "Comment" under "Routing/BFD/Configuration" menu;
*) winbox - added "g" flag under "IPv6/Routes" menu;
*) winbox - added "Host Key Type" setting under "IP/SSH" menu;
*) winbox - added "Key Owner" setting under "System/User/SSH Keys" and "System/User/SSH Private Keys" menus;
*) winbox - added "Name Format" property under "WifiWave2/Provisioning" menu;
*) winbox - added "Remote Min Tx" parameter under "Routing/BFD/Session" menu;
*) winbox - added "Startup Delay" setting under "Tools/Netwatch" menu;
*) winbox - added "USB" button under "System/RouterBOARD" menu for LtAP-2HnD;
*) winbox - added "Use BFD" setting under "Routing/RIP/Interface-Template" menu;
*) winbox - added Enable/Disable button under "Routing/RIP/Static Neighbors" menu;
*) winbox - added missing properties under "WifiWave2" menu;
*) winbox - added MQTT subscription menu;
*) winbox - allow to change port numbers for SCTP, DCCP, and UDP-LITE protocols under "IP/Firewall" menus;
*) winbox - allow to set multiple addresses and added IPv6 support under "Interface/VETH" menu;
*) winbox - allow to specify server as DNS name under "Tools/Email" menu;
*) winbox - changed "MBR Partition Table" checkbox to unchecked by default under "System/Disks/Format-Drive" menu;
*) winbox - do not show "F" flag for disabled entries under "IP/Routes" menu;
*) winbox - fixed "Address" property under "WifiWave2/Remote-CAP" menu;
*) winbox - fixed "Do" property under "Routing/Filters/Select Rule" menu;
*) winbox - fixed "Group Key Update" maximum value under "WifiWave2/Security" menu;
*) winbox - fixed "Range" property under "Routing/Filters/Num Set" menu;
*) winbox - fixed "Switch" menu for CCR2004-16G-2S+;
*) winbox - fixed entry numbering and ordering under "WifiWave2/Provisioning" menu;
*) winbox - fixed minor typos;
*) winbox - improved support for certain properties under "WifiWave2/Interworking Profiles" menu;
*) winbox - rename "DSCP" setting to "DSCP (+ECN)" under "Tools/Traffic-Generator/Packet-Templates" menu;
*) winbox - rename "Name" setting to "List" under "IP,IPv6/Firewall/Address-List" menu;
*) winbox - rename "Password" button to "Change Now" under "System/Password" menu;
*) winbox - show "unknown" value for "FS" property under "System/Disks" menu if the data is not available;
*) wireguard - added "auto" and "none" parameter for "private-key" and "presharde-key" parameters;
*) wireguard - added "wg-export" and "wg-import" functionality (CLI only);
*) wireguard - allow to specify client settings under peer menu which will be included in configuration file and QR code;
*) wireguard - request public or private key to be specified in order to create peer;
*) wireless - added more "radius-mac-format" options (CLI only);
*) wireless - fixed malformed Interworking packet elements;
*) www - fixed allowed address setting for REST API users;
*) www - fixed fragmented POST data for SCEP service;
*) x86 - added support for Mellanox ConnectX-6 Dx NIC;
*) x86 - i40e updated driver to 2.23.17 version;
*) x86 - igb updated driver to 5.14.16 version;
*) x86 - igbvf updated driver from in-tree Linux kernel;
*) x86 - igc updated driver to 5.10.194 version;
*) x86 - ixgbe updated driver to 5.19.6 version;
*) x86 - Realtek r8169 updated driver;
*) x86 - updated latest available pci.ids;
Big changes in this one. READ IT FIRST if you are thinking of trying this.
All changes work fine on my cAP ax and hAP ax2, there is a conversion process and advice is to update via router updates for better transition.
New Wireless packages
From 7.13 we are separating the older wireless package out from routeros.npk bundle and renaming wifiwave2 package to wifi. The new wifi package is now part of the routeros.npk bundle, beginning a new and exciting era for wifi features.
We are also separating core wifi features from the drivers, reducing used space on the router. Note that upgrade will take care of the new packages automatically, you do not need to worry about anything, if you use "check for updates" feature. Technically the bundle only includes the core wifi package with capsman, so devices that don't have any wireless cards, but are only used for capsman, will not use space unnecessarily if you don't install the separately available driver packages.
Due to this, you will now see the wifi menu even on devices that don't have any wireless interfaces. The new wifi package is also now compatible with more devices than before - you can install the new wifi package even on 802.11AC devices that have the ARM CPU type.* This opens up more compatibility options with the new 802.11AX devices and even allows devices to use both wireless packages (old/integrated + new wifi package) in the same device, which means you can now use a single router to run both old and new CAPsMAN.
Software upgrade PSA
Because of the introduction of a new wireless package, we would like to bring your attention, that RouterOS will now show upgrade only up to 7.12 if using an older version of software. You will have to first upgrade to 7.12 and only then newer RouterOS versions will become available to you.
RouterOS version 7.13beta has been released on the "v7 testing" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
Notice - Starting from RouterOS version 7.13, significant changes have been made to the RouterOS wireless packages. This is done due to a new product development which will require more disk space for hardware drivers so we had to split it in order to maintain old products alongside the new ones. More wireless packages are yet to come.
1. When upgrading by using "check-for-updates", all versions earlier than 7.12 will display 7.12 as the latest available version. Upgrade from v7.12 to v7.13 or later versions must be done through 7.12 in order to convert wireless packages automatically. Fresh installation with Netinstall or manual package installation works in the same manner as always.
2. Drivers for older wireless and 60GHz interfaces, as well as the wireless management system CAPsMAN, are now part of a separate "wireless" package instead of being a part of the bundle package. This package can be uninstalled if not needed.
3. The existing "wifiwave2" package has been divided into distinct packages: "wifi-qcom" and "wifi-qcom-ac", and the necessary utilities for WiFi management are now included in the RouterOS bundle. RouterOS and "wifi-qcom-ac" packages alongside each other now fit into 16MB flash memory.
What's new in 7.13beta1 (2023-Nov-09 13:15):
!) package - convert "wireless" and "wifi" packages automatically, if upgrading from v7.12;
!) wifi - split existing "wifiwave2" package into separate packages "wifi-qcom", "wifi-qcom-ac", and include required utilities for WiFi management into bundle;
!) wireless - separate "wireless" package from bundle and build as a standalone package;
*) bridge - added automatic "path-cost" values depending on interface rate;
*) bridge - added bridge interface property "port-cost-mode" with "short" and "long" arguments;
*) bridge - fixed bogus VLAN entries from wifi when vlan-filtering is not enabled;
*) bridge - improved host flush when removing VLAN on HW offloaded bridge;
*) bth - added "VPN Prefer Relay Code" option;
*) certificate - add support for multiple DNS names for Let's Encrypt;
*) certificate - fixed certificate auto renewal via SCEP when certificate contains "subject-alt-name";
*) certificate - improved initial certificate creation using SCEP;
*) cloud - improved re-connect speed after network related connection errors;
*) console - added ":grep" command;
*) console - added ":onerror" command;
*) console - added ":serialize" and ":deserialize" commands for converting values to/from JSON;
*) console - added "read" command under "file" menu;
*) console - added "where" functionality for "export" command;
*) console - added flags to "print" command with "value-list";
*) console - added interface helper for "gateway" property under "ip/route" menu;
*) console - clear console history when resetting configuration;
*) console - disallow setting existing "name" under "system/script" and "system/scheduler" menus;
*) console - fixed "export" boolean arguments when saving output to file using API;
*) console - fixed "interface/ethernet/switch/port-isolation" export;
*) console - fixed "on-event" argument highlighting under "system/scheduler" menu;
*) console - fixed graphic distortions in WinBox;
*) console - fixed issue where API incorrectly asks for missing arguments;
*) console - fixed printing of "on-event" under "system/scheduler" menu;
*) console - fixed printing to file using API;
*) console - ignore negative values for ":delay" command;
*) console - improved flag printing in certain menus;
*) console - improved stability when running "tool/ping" from API;
*) console - removed "route-cache" setting from "ip/settings" menu;
*) console - replace reserved characters in file and script names with underscores;
*) console - resolve "wifiwave2" directory to "wifi";
*) console - show "l2vpn-link" address family under "routing/route" menu;
*) console - use more compact login screen for empty branding;
*) defconf - expire password when reverting configuration;
*) defconf - hide default configuration for users without "sensitive" policy;
*) defconf - updated configuration with new "wifi" directory;
*) defconf - use "fan-min-speed-percent=25" for CRS354-48G-4S+2Q+ device;
*) defconf - use device factory preset credentials when using CAPs mode;
*) defconf - use one SSID and enable FT when using "wifi" packages;
*) ethernet - improved packet CPU core classifier for Alpine CPUs for non IPv4/IPv6 traffic;
*) fetch - added "http-content-encoding" setting;
*) fetch - allow to receive HTTP response headers;
*) fetch - require "ftp" user policy;
*) firewall - added "nat-pmp" support;
*) firewall - added new IPv6 filter arguments "icmp-err-src-routing-header" and "icmp-headers-too-long" for "reject-with" setting;
*) firewall - do not mark all IPv6 GRE packets as invalid;
*) firewall - fixed altered address-list when upgrading from RouterOS v6;
*) firewall - fixed connections being tracked when tracking is disabled;
*) firewall - fixed IPv6 address-list timeout;
*) firewall - removed "prohibited" and "unreachable" IPv4 address-type arguments;
*) health - dynamically add and remove invalid sensors (e.g. sfp-temperature);
*) hotspot - fixed incorrect host moving to VLAN 0 when receiving packets through bridge;
*) ike2 - fixed ike2 double reply;
*) ipv6 - do not send out IPv6 RA deprecate message for re-used prefix;
*) isis - added IS-IS protocol support (CLI only);
*) l3hw - fixed routing for IPsec encapsulated packets;
*) leds - fixed LED indication in multi-APN setup for Chateau;
*) leds - improved LED indication during modem registration state for Chateau;
*) log - added "fetch" topic;
*) lora - fixed issue with lost LoRa configuration when rebooting the device;
*) lte - added RNDIS support for neoway N75-EA modem;
*) lte - added support for FOTA firmware upgrade from custom URL for R11eL-FG621-EA;
*) lte - disabled IMS service for Chateau 5G on A1 HR network;
*) lte - fixed rare cases where Chateau 5G in passthrough mode may stop forwarding packets;
*) lte - improved SIM slot status change notification handling for MBIM modems;
*) lte - replaced "passthrough-subnet-selection" with "passthrough-subnet-size" setting (CLI only);
*) lte - show each CA band in a new line;
*) mipsbe - improved system stability when removing USB devices;
*) mmips - properly mount and unmount USB devices;
*) modem - added option to read SMS using MBIM interface;
*) mpls - added "te-tunnel" property for VPLS monitor (CLI only);
*) mpls - fixed IPv6 RSVP-TE;
*) mpls - improved logging;
*) netinstall-cli - added more details to help messages;
*) ovpn - improved memory allocation during key-renegotiation;
*) ovpn - removed "ping-timer-rem" option from client config file;
*) package - added warning log about missing "wireless" or "wifi" package;
*) pimsm - improved elected BSR change;
*) poe-out - improved firmware upgrade stability for AF/AT controlled boards;
*) ppp - added remote-ipv6-prefix to IPv6 firewall address-list if "address-list" property is provided;
*) ppp - allow at-chat and info commands in "waiting for packets" state for modems with shared data/info channel;
*) ppp - improved IPv6 link-local address uniqueness;
*) pppoe-server - fixed connection count limit per license level;
*) profiler - improved "disk" and "supout.rif" classifiers;
*) qos-hw - added initial congestion avoidance support for 98DX224S, 98DX226S, and 98DX3236 switch chips (CLI only);
*) qsfp - added support for QSFP-to-SFP adapters;
*) quickset - show DDNS name as VPN address for devices with new style serial number;
*) sfp - improved link establishment with certain modules for hEX S device;
*) sfp - improved SFP interface handling for 98DX224S, 98DX226S, 98DX3236, 98DX8208, and 98DX8216 switch chips;
*) ssh - fix error that caused large chunks of text not being pasted in their entirety into console;
*) supout - added VXLAN FDB section;
*) switch - fixed service VLAN tagged IP multicast packets for 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255 switches;
*) system - added "rtrace" debugging tool (CLI only);
*) traffic-generator - improved system stability when modifying interfaces;
*) usb - added support for RTL8152 USB ethernet on ARM, ARM64 and x86;
*) vpls - improved performance when decapsulating data;
*) vrf - fixed ICMP reply lookup;
*) webfig - allow to display comments in multiline or compact modes;
*) webfig - make table headers always visible;
*) webfig - use local storage for user preferences;
*) wifi - added "flat-snoop" tool for surveying WiFi APs and stations (CLI only);
*) wifi - added "remove" command in "capsman/remote-cap" menu;
*) wifi - after radar detections, avoid selection of channels not permitted by the user;
*) wifi - changed CAPsMAN generated certificate common name;
*) wifi - fixed EAP authentication failures when the Session-Timout RADIUS attribute is defined;
*) wifi - fixed occasional failures to start on 20/40mhz-eC channels for 2.4GHz 802.11ax interfaces;
*) wifi - fixed overridden datapath settings on CAP when unsetting from CAPsMAN;
*) wifi - make slave APs use datapath bridge settings inherited from master by default;
*) wifi - removed "openflow-switch" setting;
*) winbox - added "Hw. Offload" property under "IP/Firewall/Filter" menu;
*) winbox - added "none" argument for "Preshared Key" under "WireGuard/Peers" menu;
*) winbox - added "Ping" button under "IP/DHCP Server/Leases" menu;
*) winbox - added "Tx bps" and "Rx bps" monitor values under "WiFi/Registration" menu;
*) winbox - added icon to entries under "WiFi/Access List" menu;
*) winbox - added missing "qos-classifier" argument for "Hw. Caps" under "WiFi/Radios" menu;
*) winbox - added missing arguments for "MAC Format" under "Wireless/Security Profiles/RADIUS" menu;
*) winbox - allow opening entries under "WiFi/Registration" menu;
*) winbox - fixed default "Name Format" property under "WiFi/Provisioning" menu;
*) winbox - fixed minor typo under "Routing/BFD" menu;
*) winbox - updated "wireless" and "wifi" menus;
*) wireless - fixed "wlan1" default name for RBSXTsqG-5acD and RBLDFG-5acD;
*) wireless - fixed snooper information gathering from re-assocation requests;
Still no sign of the power levels for the UK being correted, how tedious!
2402-2482/20
5170-5250/23/indoor
5250-5330/23/indoor/dfs
5490-5730/30/dfs
5735-5875/14
state: running
channel: 5745/ax/Ceee
registered-peers: 1
authorized-peers: 1
tx-power: 9
available-channels: 5745/ax/Ceee
What's new in 7.13beta3 (2023-Nov-24 13:52):
*) bridge - fixed HW offload enable with multiple switches (introduced in v7.13beta1);
*) bridge - improved HW offload enable;
*) certificate - fixed CRL check (introduced in v7.13beta1);
*) certificate - fixed host certificate verification if host is IP address (introduced in v7.13beta1);
*) certificate - fixed manual URL addition for CRL (introduced in v7.13beta2);
*) certificate - improved CRL signature verification and download error messages;
*) certificate - use error topic for CRL update failures;
*) console - added unset option for "ssid-regex" and "allow-signal-out-of-range" properties under "interface/wifi/access-list" menu;
*) console - fixed misaligned columns (introduced in v7.13beta1);
*) console - improved stability when removing script;
*) defconf - fixed bogus wifi password on certain Audience devices;
*) defconf - use "WISP Bridge" default configuration mode for RBGrooveGA-52HPacn device;
*) fetch - added "http-auth-scheme" parameter, allows to select HTTP basic or digest authentication;
*) fetch - added raw logging;
*) ospf - fixed LSA Type3 advertisement for OSPFv2;
*) qsfp - fixed supported rates for breakout cables (introduced in v7.12);
*) sfp - added "1G-baseT" link mode for modules that supports "2.5G-baseT" mode;
*) sfp - allow 2.5G rates only in forced link mode;
*) sfp - fixed SFP and combo interface handling for CRS328-4C-20S-4S+ device (introduced in 7.13beta1);
*) sfp - ignore "rx-loss" in forced link mode;
*) sfp - ignore irrelevant extended compliance code for SFP modules;
*) sfp - show 10M and 100M supported rates for RJ45 copper modules;
*) ssh - added cipher and hash acceleration for ARM64 and x86;
*) supout - include missing wireless information (introduced in v7.13beta1);
*) wifi - enable protected interworking ANQP responses;
*) wifi-qcom - added fast-path for received packets;
*) winbox - fixed memory allocation (introduced in v7.13beta2);
This one is worth the update if your using ax devices.
What's new in 7.13rc2 (2023-Nov-30 17:02):
*) bth - improved automatic firewall rule generation process;
*) certificate - added HTTP redirect support for CRL download;
*) console - fixed user login through RADIUS (introduced in v7.13beta1);
*) defconf - use "fan-min-speed-percent=25" for CRS354-48P-4S+2Q+ device;
*) ftp - improved upload and download speeds;
*) ospf - fixed missing opaque bit in opaque LSA;
*) ospf - fixed missing OSPF interface on L2TP interface reconnect;
*) ssh-client - fixed bogus output in interactive mode (introduced in v7.13beta3);
*) system - improved incoming and outgoing TCP connection performance;
*) system - improved internal process communication performance;
*) wifi - added "radio-mac" variable for "name-format" provisioning setting;
*) wifi - create first interface without number when using "name-format" provisioning setting;
*) wifi - fixed cap interface hangs with "busy" status (introduced in v7.13beta3);
*) wifi - improved CAPsMAN stability during provisioning;
*) winbox - improved connection speed;
It’ll be worth the update once it goes stable. MikroTik beta software is generally not fully ready, even if they describe it as a ‘release candidate’ status.
It's been a journey of twists and turns for me over the Last 12 months with Mikrotik ax stuff anyway, And I wouldn't say their main releases are any better than an RC tbh.
But having said that the journey for Basic use equpiment ie WiFi 6 hAP/cap is maturing now in a good direction and very useable imo.
The current AX gear is excellent. Far better than their reputation. And then you look at the equivalent gear from any other manufacturer, they’re still struggling to just keep up with the last generation never mind the current generation (no Wifi6E as of yet). When it comes to routing MikroTik are absolutely the dogs danglies and their switches are excellent and very reasonably priced. Their WWAN gear is some of the best on the market but WiFi just doesn’t seem to be their thing.
Still deciding whether to buy an RB5009 or not now the WiFi is stable. It might all hinge on Mikrotik pushing a power update for the higher band or not.
What's new in 7.13 (2023-Dec-14 09:24):
*) certificate - added support for certificates with key size 16384;
*) certificate - fixed CRL updating;
*) console - added "interface" name when printing "interface/pppoe-server" entries;
*) defconf - fixed configuration for Audience with "wifi-qcom-ac" package;
*) defconf - fixed wireless band and channel-width selection (introduced in v7.12);
*) defconf - improved wifi interface detection after upgrade;
*) disk - fixed hang on reboot when network file systems mounted;
*) ethernet - improved system stability for L009 and hAP ax lite devices;
*) iot - fixed incorrect LoRa ACK packet handling during downlink messaging (introduced in v7.12);
*) lora - added CUPs protocol support;
*) ppc - fixed RouterOS bootup (introduced in v7.12);
*) route-filter - improved performance;
*) sfp - fixed link establishment with S+DA0001 DAC cables;
*) sfp - improved link establishment for SFP copper modules;
*) ssh - added cipher and hash function acceleration for ARM64 and x86 architectures;
*) supout - added multiple WiFi sections;
*) wireless - keep configuration after manual package removal;
What's new in 7.14beta3 (2023-Dec-19 13:31):
*) 6to4 - make "ipsec-secret" sensitive parameter;
*) api - improved REST API stability when processing invalid requests;
*) api - properly return SNMP OIDs when requested;
*) arm - improved system stability when using microSD on RB1100Dx4;
*) bridge - added MLAG support for MSTP bridges;
*) bridge - added MVRP support (CLI only);
*) bridge - improved bridge VLAN configuration validation;
*) bridge - improved configuration speed on large VLAN setups;
*) bridge - improved protocol-mode MSTP functionality;
*) bridge - improved protocol-mode STP and RSTP functionality;
*) bridge - make "point-to-point=yes" default value for non-wireless bridge ports;
*) bridge - try to set wireless bridge ports as edge ports automatically;
*) bth - added simple "Back To Home Users" manager under IP/Cloud menu;
*) console - added missing "where" clause for "/ipv6/firewall/filter" table print command;
*) console - added ":tolf" and ":tocrlf" commands for converting line break to/from LF or CRLF;
*) console - do not accept negative or too large values for ":delay" command;
*) console - do not allow to use out-of-range values for time type fields;
*) console - fix configuration export when user does not have a "sniff" policy;
*) console - hint on reset command help that ".rsc file" is required for "run-after-reset" parameter;
*) console - improved editor functionality in full screen mode;
*) console - increased maximum file content length that can be managed through command line to 60 KB;
*) container - improved VETH interface management responsiveness and reliability;
*) container - restrict "/container/shell" menu for users without "write" permissions;
*) defconf - use "fq_codel" queue as default interface queue for wired ports on LTE devices;
*) disk - added exFAT and NTFS mount/read/write support (CLI only);
*) disk - properly unmount disk when it is disconnected;
*) ethernet - improved cable-test reliability for hAP ax3 PoE out port;
*) ethernet - resolved minor memory leak while processing packets;
*) fetch - do not require "content-length" for HTTP (introduced in v7.13);
*) fetch - fixed IPv4 address logging (introduced in v7.13);
*) fetch - treat any 2xx HTTP return code as success (introduced in v7.13);
*) filesystem - improved filesystem integrity for several RB3011 units with automatic firmware upgrade;
*) firewall - added "creation-time" parameter for IPv6 address list entries;
*) firewall - increased default "udp-timeout" value from 10s to 30s;
*) health - improved fan control on CRS3xx and CCR1016-12S-1S+r2;
*) iot - added LoRa CUPs protocol support;
*) iot - fixed modbus partial frame reception issue;
*) iot - improved modbus Tx/Rx switching behaviour;
*) leds - fixed "type=on" LED behaviour after reboot;
*) leds - fixed wireless type of LED triggers for routers using WiFi package;
*) lte - refactored AT command control for AT modems;
*) modem - fixed SMS removal (introduced in v7.13);
*) ovpn - added support for pushing routes;
*) ovpn - improved OVPN configuration file import process;
*) ovpn - improved key-renegotiation process;
*) poe-out - improved PoE out reliability on routers with a single PoE out interface;
*) ppp - log an error when IPv6 DHCP pool is exhausted;
*) route - improved route print "count-only" process speed;
*) route - improved stability on route table lookup;
*) sfp - improve high-power SFP module initialization;
*) ssh - improved SSH performance on ARM and MIPS devices;
*) ssh - refactored SSH service internal processes;
*) switch - improved 100G interface stability for 98DX4310 and 98DX8525 switches;
*) switch - minimise potential packet overflows on CRS354;
*) system - changed build time format according to ISO standard;
*) system - expose "lo" interface;
*) system - improved RAM allocation for L009UiGS-RM;
*) system - improved system stability when processing packets in FastPath (introduced in v7.13);
*) system - provide more precise "total-memory" value for ARM devices;
*) system - provide more precise "total-memory" value under "System/Resources" menu for L009 and hAP ax lite routers;
*) tr069-client - show 5G signal info in X_MIKROTIK_5G nodes only for 5G NSA bands;
*) wifi - added "station-pseudobridge" interface mode (CLI only);
*) wifi - use correct CAP identity for interface name provisioning after it has been changed by remote-cap/set-identity;
*) winbox - added "accept-protocol-version" parameter to the L2TP server settings;
*) winbox - added "mode-button" and "switch" menus for L41G-2axD&FG621-EA;
*) winbox - added "page-refresh" setting to the Graphing settings;
*) winbox - aded Preboot Etherboot settings to the System/RouterBOARD/Settings menu;
*) winbox - do not show USB settings for CRS devices that does not need it;
*) winbox - improved connection speed and reliability;
*) winbox - improved route table automatic refresh process for static routes;
*) winbox - include "te-tunnel" parameter in VPLS interface monitor;
*) winbox - properly validate "passthrough-subnet-size" in the LTE APN settings;
*) winbox - removed "sfp all" option from combo port settings;
*) winbox - renamed "Wireless Table" menu to "Wifi";
*) winbox - show "routing-table" column under IP/Route menu by default;
*) wireguard - do not allow to use multiple WireGuard interfaces on the same "listen-port";
*) wireguard - optimised and improved WireGuard service logging;
Best place to buy Microtik hardware?
I'm leaning towards the L009 AX router as a replacement for my very old and very not-supported Asus AC66u....
LinITX is the biggest importer in the UK. I normally get mine from Getic in Latvia because they’re cheaper in volume.
The L009 is only 2.4G AX, Hap ax2/ax3 and cap ax would be a better choice. Or if you have a bit more to spend the 5009 and a couple of cap ax's.
I found LinITX and MS Dist to be ok to buy from.
I would bodyswerve MS Dist as they drop ship from Poland and they have shocking aftersales. I was buying £5K per month from them and they ghosted me over a defective £45+VAT hAP AC. Even if LinITX are substantially more expensive you will get phone and email support from them even if you only buy one unit.
Yeah I've been doing some reading and not having 5ghz is a shame, I'd have liked the 8 ports on the L009.
