**Official MikroTik Hardware **
There's the MikroTik hAP ax3 which has a 2.5Gb port, you could then bond some 1Gb ports into a switch. A bit clunky but devices with "some" ports above 1Gb are very expensive generally.
Your best bet is likely to be one of those mini PCs with 4x Intel 2.5Gb adapters (the non-broken revision) and an OS of your choice
What about using just a CRS305-1G-4S+IN as a direct replacement for the USG3P? It's not like the USG is at all powerful?
Uplink to my 16 port Switch then use the 4 SFP+ for a 2.5g WAN and 3 x 10gbe LAN?
Could I configure it like that in the RouterOS?
You can configure it, definitely and see @Caged‘s previous comments about the routing capabilities of the Mikrotik CRS devices.
Ah so performance would be a lot worse doing that, just seen the test results page on the product listing.
Back to thinking about the RB5009 and a CRS305 then.
The Little Guy arrived... \o/ Hap AX2
I have just a few out of the box tests 20/40/80 5G
Using AX200 Windows 11 22H2
Code:
So I Have CPU temp 60c while testing and 57c idle after testing
cpu Usage 30% ish hammering the wifi --bidir
cpu usage 25% ish for uploads   cpu temp 60c
cpu usage 22% ish for downloads cpu temp 60c
Averages.
Nothing fell over yet, happy so far.
iperf3 -c 192.168.88.252 -b 400M --bidir
Connecting to host 192.168.88.252, port 5201
[  5] local 172.19.208.25 port 59548 connected to 192.168.88.252 port 5201
[  7] local 172.19.208.25 port 59550 connected to 192.168.88.252 port 5201
[ ID][Role] Interval           Transfer     Bitrate         Retr  Cwnd
[  5][TX-C]   0.00-1.00   sec  47.8 MBytes   401 Mbits/sec    0   1.67 MBytes
[  7][RX-C]   0.00-1.00   sec  47.5 MBytes   398 Mbits/sec
[  5][TX-C]   1.00-2.00   sec  47.6 MBytes   400 Mbits/sec    0   1.80 MBytes
[  7][RX-C]   1.00-2.00   sec  47.7 MBytes   400 Mbits/sec
[  5][TX-C]   2.00-3.00   sec  47.8 MBytes   401 Mbits/sec    0   1.80 MBytes
[  7][RX-C]   2.00-3.00   sec  47.7 MBytes   400 Mbits/sec
[  5][TX-C]   3.00-4.00   sec  47.6 MBytes   399 Mbits/sec    0   2.01 MBytes
[  7][RX-C]   3.00-4.00   sec  47.7 MBytes   400 Mbits/sec
[  5][TX-C]   4.00-5.00   sec  47.8 MBytes   401 Mbits/sec    0   2.01 MBytes
[  7][RX-C]   4.00-5.00   sec  47.5 MBytes   398 Mbits/sec
[  5][TX-C]   5.00-6.00   sec  47.6 MBytes   400 Mbits/sec    0   2.01 MBytes
[  7][RX-C]   5.00-6.00   sec  48.0 MBytes   403 Mbits/sec
[  5][TX-C]   6.00-7.00   sec  47.6 MBytes   400 Mbits/sec    0   2.01 MBytes
[  7][RX-C]   6.00-7.00   sec  47.1 MBytes   395 Mbits/sec
[  5][TX-C]   7.00-8.00   sec  47.8 MBytes   401 Mbits/sec    0   2.01 MBytes
[  7][RX-C]   7.00-8.00   sec  48.0 MBytes   403 Mbits/sec
[  5][TX-C]   8.00-9.00   sec  47.6 MBytes   400 Mbits/sec    0   2.01 MBytes
[  7][RX-C]   8.00-9.00   sec  47.6 MBytes   399 Mbits/sec
[  5][TX-C]   9.00-10.00  sec  47.8 MBytes   401 Mbits/sec    0   2.01 MBytes
[  7][RX-C]   9.00-10.00  sec  47.7 MBytes   400 Mbits/sec
[  5][TX-C]   0.00-10.00  sec   477 MBytes   400 Mbits/sec    0             sender
[  5][TX-C]   0.00-10.01  sec   477 MBytes   399 Mbits/sec                  receiver
[  5] local 172.19.208.25 port 59560 connected to 192.168.88.252 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  92.1 MBytes   773 Mbits/sec   15   1014 KBytes
[  5]   1.00-2.00   sec  88.8 MBytes   744 Mbits/sec   39    794 KBytes
[  5]   2.00-3.00   sec  86.2 MBytes   724 Mbits/sec   86    623 KBytes
[  5]   3.00-4.00   sec  85.0 MBytes   713 Mbits/sec   19    506 KBytes
[  5]   4.00-5.00   sec  78.8 MBytes   661 Mbits/sec    3    443 KBytes
[  5]   5.00-6.00   sec  76.2 MBytes   640 Mbits/sec    0    562 KBytes
[  5]   6.00-7.00   sec  78.8 MBytes   661 Mbits/sec    5    492 KBytes
[  5]   7.00-8.00   sec  78.8 MBytes   661 Mbits/sec    0    599 KBytes
[  5]   8.00-9.00   sec  81.2 MBytes   682 Mbits/sec   17    486 KBytes
[  5]   9.00-10.00  sec  80.0 MBytes   671 Mbits/sec    0    600 KBytes
[  5]   0.00-10.00  sec   826 MBytes   693 Mbits/sec  184             sender
[  5]   0.00-10.01  sec   822 MBytes   690 Mbits/sec                  receiver
iperf Done.
 iperf3 -c 192.168.88.252 -R
Reverse mode, remote host 192.168.88.252 is sending
[  5] local 172.19.208.25 port 59588 connected to 192.168.88.252 port 5201
[  5]   0.00-1.00   sec  87.9 MBytes   737 Mbits/sec
[  5]   1.00-2.00   sec  94.5 MBytes   792 Mbits/sec
[  5]   2.00-3.00   sec  97.7 MBytes   819 Mbits/sec
[  5]   3.00-4.00   sec  96.6 MBytes   811 Mbits/sec
[  5]   4.00-5.00   sec  97.6 MBytes   819 Mbits/sec
[  5]   5.00-6.00   sec  95.7 MBytes   803 Mbits/sec
[  5]   6.00-7.00   sec  99.1 MBytes   831 Mbits/sec
[  5]   7.00-8.00   sec  95.0 MBytes   797 Mbits/sec
[  5]   8.00-9.00   sec  95.9 MBytes   804 Mbits/sec
[  5]   9.00-10.00  sec  97.6 MBytes   819 Mbits/sec
[  5]   0.00-10.00  sec   960 MBytes   805 Mbits/sec                  sender
[  5]   0.00-10.00  sec   958 MBytes   803 Mbits/sec                  receiver
iperf Done.
Code:
Averages.
iperf Done.
iperf Done.
Interesting, hadn't seen anywhere who had any stock. What version of RouterOS is it running?
Code:
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 7.5 (c) 1999-2022
Code:
I think you can upgrade your packages and routerBOARD firmware to 7.6 stable now.
The hAP ax3 would have been a better fit for the 2.5Gbps port on the SH5, but never mind
We ordered it way before the AX3 came out. We also only have 200/20. The AX2 will be replacing a WDR3600 with openwrt just for the 2.4g, I also have another A7 as my main TV point switch/wifi which gives 300Mbps. The long term plan is to get an AX3 later on if we upgrade to faster speeds. we don't have any internal big speed needs 1G is enough. The SH5 is just pure curiosity! It's also my first venture into MikroTik for learning what it has to offer.
I guess we can extend the MikroTik family as and when if we like it.
Any wise words would be appreciated before I dive in and try to auto-update this Hap AX2 to the latest RouterOS 7.6 as of writing.
I got my config backed up safe and sound.
The simple way is from Winbox, system - packages - check for updates, then download and install. Then reboot, then system - routerBOARD, upgrade and reboot, then you should be golden.
Just picked up a cheeky SRJ10 from the auction site. Don't understand why they are so hideously expensive for an SFP>Copper converter in general but this will allow me to hook my B660 board into the CRS326 and at least get 2.5Gb into my network now (yes I have multigig on the backbone so it's not going to waste).
Am really tossing up at the moment though, got a Dell R210 (E3-1220L) running ESXi with a CHR. Built with the intention of doing some really precise queueing but then have taken the lazy option and gone FQ_CoDel on my PPPoE interface not that it ever fills up.
Also have a Hex R3 which is sitting doing nothing and I can't help but think is the power draw worth it for the R210?
Nothing is broken so I get there's no need to fix it and the resale of the R210 is probably non existent but yeah.... hardware struggles.
I must say I was a little worried how it might go! I didn't even have time to sip on a cup of coffee and BOOM it was all done.
I think they have the balance right here and most (tech savy) people could install this device without much trouble. I did find things like webfig doesn't WoW me. Also Winbox (Snap) on ubuntu (tried apt as well) just doesn't give the same pop back up experience that the Windows version does. No great shakes... it works. What else - oh yes the 5G fell over about 4 times in 12 hours. Need to look a little harder now I've updated.
The QOS It just works. As a first time buyer/User We are happy and would buy again, great product so far.
So before I go down this rabbit hole, Is it worth enabling containers and moving my pi-hole over to the AX2, not sure of space etc/ 90MB remaing logs.... blah, or just leave that for a bigger device.
I have a pi-hole container set up on my Mikrotik 5009 running ROS7.6, that has the 1GB of ram, I run the pi-hole on a 32GB Sandisk cruzer usb stick. Last time I checked I had 550MB of ram free on the set up. I used the info from Network Berg's Youtube video and Mikrotik wiki info to get it set up and unning nicely. I have my wireguard VPN set on my little hAP lite, this is just used for online streaming over the 2.4ghz wifi and fast ethernet for my HTPC.
  • Like
Reactions: R3X
@Super Tigers
From watching that Video the answer is NO, the device doesn't have a USB port and also the docker image is 500MB.
