- 25 Mar 2004
- Fareham
4K is nice and all, but the OLED handles a good quality 1080p source easily as well, and can still look amazing even without being 4K.
Hi Roger when you first start a 4K UHD video on amazon it initially starts of at 1080p and then after minute or so it should increase to UHD resolution.
Try playing The Grand tour and if the tv switches to HDR mode in the top right corner then it is working correctly.
y question is this...I sit 3M from my 55" tv....is it worth me upgrading to BT Infinity for 4K Amazon/Netflix? Will I see the difference?
If the cost of upgrading to BT Infinity is only a few £ a month then i would say yes its worth the upgrade there is more and more content coming now in 4K/HDR and even the BBC iplayer will be going to jump to 4K at some point in the near future.
Did you get your 4K fish tank video yet ?
I can see a difference from around 4m so you should be able to notice a difference.
Your internet is not fast enough for youtube 4k.
I'm playing 4k uhd shows off netflix...how do I know it's a 4K stream and not 1080?
I get the Dolby Vision logo on Marxo Polo/Netflix...is thst 4k ?
Well on the B6 remote there is no info button so you cant bring up the resolution info box on Netflix.
Yes, although personally I would not rate a lot of the 4k/hdr content on Netflix, most of it has that horrible grain effect.
Yes, I noted the lack of resolution button. I know people set the de judder to 0 but I've got mine set to 2 and deblur 10, I've noticed the odd bit of ghosting/motion issue occasionally...any tips/settings for perfect motion?
I'm assuming we will get Youtube HDR content at some point?
Been waiting months for this also but doing some reading it seems people think its a hardware issue.. an external device like the Chromecast ultra might be the only option for youtube HDR.
Be interesting to know whats lacking if that's the case.
