The C6 got HLG is the latest update as it now works with the iplayer beta HLG trial. The B6 may have it now or its coming.
Yeah my B6 has had HGL support for a while now.
Your'll need to load the firmware manually.
Did you get that from the official Russian website, as Im pretty sue LG UK site only has the older firmware still with no hlg support.
Just so you know I loaded the latest firmware 05.30.03 the other night and the detail in the blacks/shadows is quite improved (using the same previous settings)
LG definitely have tweaked something with firmware 05.30.03.
Well worth doing!
But wasn't there a firmware release that made Game mode HDR worse? Have they released a further improvement since then?
Not sure, its been mentioned in the past the HDR game mode was dark but not found that an issue, apparently with the latest 5.** firmware for HDR game content everyone says to put Dynamic contrast to high, think even LG recommend this as well, NOTE: only for HDR game mode.
New version 05.30.03 firmware is officially on the LG UK site for the B6
According to AV Forums people, it improves black levels.
It also adds new background images to the 'no signal screen' and "changes the Amazon HDR mode"
http://www.lg.com/uk/support/software-firmware?search=OLED65B6V&pageVisibleFlag=2
Just installed it myself.
Quite frankly the old firmware I was on (04.31.25) didn't really have a bright HDR game mode anyway, so I had DC on high anyway for HDR Game. Couldn't see any difference between the new firmware and the old in terms of that.
Breakthrough though - Shadow Warrior 2 worked fine with HDR and the receiver was showing Dolby Digital. It seems that if you send a bitstream signal over HDMI instead of PCM then it uses less bandwidth and works great.
Now to test Hitman...
