- 30 Sep 2005
yes, but is it through Virtual Desktop or something (wireless) or via cable ?
I certain it's wireless to VD, and that the cable is just for power.
Difficult to decide if Pico 4 is better than Quest 2. Yes it has better battery and resolution, but there are drawbacks. 90Hz refresh for Pico 4 compared to 120Hz on Quest 2. Same GPU, CPU and chipset - so nothing has changed there in 2 years.
What makes this better?
There's a 256GB Q2 I'm interested in, unless the Pico 4 can sway me.oh yes, i forgot its got more RAM
also 128Gb storage
oh wait, so has the Q2 now lol
What are you going to be using the headset for? Standalone or PCVR. What games are wanting to be playing, all of them or only a specific genre? These things should influence your decision.There's a 256GB Q2 I'm interested in, unless the Pico 4 can sway me.
The XR2 chip in Quest 2 runs at 1.4Ghz. In Pico it runs at 2.8ghz due to bigger battery and active cooling. So it's a performance upgrade of 100%.
Considering Pico's resolution is 30% higher that should leave a good amount of room for more stable frame rate, so a more consistent 90hz hopefully.
Not sure how much software on Quest 2 is really 120hz? I'd be really surprised if it has the oompth at 1.4ghz to run many games at that frame rate. Of course PCVR could. But I think most games on Quest 2 itself run at either 72fps (like beat saber) or 90hz for very simple games.
wow, i did not know that, 2.8 GHz ?
the Quest 2 120Hz, hardly anything runs at that at the moment, only a couple of games
but there is hand tracking on the Q2 but ive never used it, waiting for a game that i want with this !
Quest 2 does have a tiny fan inside, though I'm unsure how effective it is considering there is no direct grill for airflow (like on Pico 4), either say its clocked at half speed according to Carmack. I wonder if any reviewer has been asked about the Pico 4's fan and how active it is?, can they feel the air moving from the vent after heavy use?, that would be interesting to know.
