- 21 Dec 2019
- Planet Thanet
Gpuz will tell you
What pcie speed it's running at
Gpuz will tell you
Thanks!I'll check it for you one sec
Thanks!
I played 10 minutes of DayZ with GPU-Z open as well like you said.
Here's a screenshot after I finished playing:
What does that suggest then?Hang on just looked zoomed in and can see I dip in clocks, memory and power, perfcap does drop off, in that case there would be a stutter 100%
When I say new build I built it in Feb and always had this issue. The PSU was bought new.If perfcap ever drops that's normally a power issue, is the 1kw unit new or taken from a older build?
Do you have decent wiring in your home, it can play into factor too.
It's a fully modular ATX 3 yes mate.Is the PSU you bought fully atx 3 or higher certified. Could be a bad PSU at this point.
How is the 4090 connected a gen 5 cable or using a splitter with 8pin leads?
I can't check right now as I'm out but I think it is a gen 5 cable.
I was under the impression 1000w would be more than enough for my build?
Maybe rainforest a psu then too. Same applies you can test and return hassle free.It's a fully modular ATX 3 yes mate.
Which PSU would you recommend me rainforesting?Maybe rainforest a psu then too. Same applies you can test and return hassle free.
Isn't the one I've got though good enough? It seems very well reviewed?be quiet are a sold option, i run a 1500w titanium unit, way overkill but it'll last![]()
