- 12 Mar 2012
I ran the BT Speed Test which states that I now have an IP profile 56.46Mbps. Upstream rate IP profile is 20Mbps. Actual DL speed achieved during the test was 50Mbps and UL speed was 13.84Mbps. Using Speedtest.net to the Manchester server, my actual DL speed was now 54.51Mbps and UL was 14.29Mbps.
Well, your IP Profile now more or less matches the 96.79% of sync speed.
Did you restart the modem, or has the connection re-synced itself?
Code:# xdslcmd info --pbParams xdslcmd: ADSL driver and PHY status Status: Showtime Retrain Reason: 0 Max: Upstream rate = 14616 Kbps, Downstream rate = 48908 Kbps Path: 0, Upstream rate = 15963 Kbps, Downstream rate = 58324 Kbps Discovery Phase (Initial) Band Plan US: (0,95) (868,1207) (1972,2783) DS: (32,859) (1216,1963) (2792,3939) Medley Phase (Final) Band Plan US: (0,95) (868,1207) (1972,2783) DS: (32,859) (1216,1963) (2792,3939) VDSL Port Details Upstream Downstream Attainable Net Data Rate: 14616 kbps 48908 kbps Actual Aggregate Tx Power: 6.8 dBm 13.4 dBm ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 5.4 28.1 42.1 N/A 14.2 34.7 53.6 Signal Attenuation(dB): 8.1 27.2 41.3 N/A 14.2 34.7 53.6 SNR Margin(dB): 5.1 5.1 5.0 N/A 3.0 3.1 3.3 TX Power(dBm): -4.1 -17.0 6.4 N/A 10.8 7.8 5.9
Strangely, my sync rate is yet again higher than my attainable rate. Is this likely due to my DL SNR now being 3.2 (see below)?
Code:# xdslcmd info --show xdslcmd: ADSL driver and PHY status Status: Showtime Retrain Reason: 0 Max: Upstream rate = 14623 Kbps, Downstream rate = 48904 Kbps Path: 0, Upstream rate = 15963 Kbps, Downstream rate = 58324 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 3.2 5.1 Attn(dB): 0.0 0.0 Pwr(dBm): 13.4 6.8 VDSL2 framing Path 0 B: 239 223 M: 1 1 T: 64 64 R: 0 16 S: 0.1310 0.4464 L: 14661 4301 D: 1 1 I: 240 120 N: 240 240 Counters Path 0 OHF: 1217692 358935 OHFErr: 1390 2 RS: 0 1489867 RSCorr: 0 18 RSUnCorr: 0 0 Path 0 HEC: 122 0 OCD: 0 0 LCD: 0 0 Total Cells: 287203237 0 Data Cells: 8350949 0 Drop Cells: 0 Bit Errors: 0 0 ES: 72 2 SES: 2 0 UAS: 16 16 AS: 2564 Path 0 INP: 0.00 0.00 PER: 2.09 7.14 delay: 0.00 0.00 OR: 91.63 31.36 Bitswap: 622 283
I still believe that I have an exceptionally noisy line that is affected by any additional interference.
I would say the low attainable rate is definitely down to the low SNRM.
What was SNRM reported as immediately after obtaining the 58324 Kbps sync speed?
For your connection, Interleaving is off for both DS & US (D: 1 1)
Inpulse Noise Protection is not applied (INP: 0.00 0.00)
& Delay is off (delay: 0.00 0.00)
This suggests that DLM does not see your connection as particularly noisy, or suffering from interference.
Although, it appears the current connection had been up for only 43 minutes or so (AS: 2564) at the time you grabbed the stats.
Have you tried out the Windows graphing scripts that will convert all the data into a visualisation of your connection?
Snapshot graphs:-
Ongoing graphs:-
