The upstreams so far are disappointing I hope its something that will improve with the main 80/20 roll out... but i doubt it
In some cases they're capped to 15Mb/s for some reason.
I dont no, sorry...Have you got any stats before you was on trial?
Upload speed achieved during the test was - 16.27Mbps
Additional Information:
Upstream Rate IP profile on your line is - 20 Mbps
@Bald_Eagle1 I believe you have aluminium between you and the cab correct?
and the length is about 650m?
Not that I am aware of
This is the first thing I would find out, I have aluminium all the way to the cab, my length is 580m and It's been there for over 30 years, this has impacted my speed a great deal!
Well, as I achived a sync speed of 35Mb over the "at least" 800m when FTTC was installed using the old 8c profile, I assume it is copper, or not much of it to be aluminium.
I have asked various visiting engineers, but it must be a "secret" as none of them have confirmed either way
One engineer came quite close when he said some of it "might" be aliuminium.
If anything, following the switch to the 17a Profile in October, I believe my connection should now be quicker/more stable.
My Attainable Rate now varies between 34 Mb & 36.3Mb, but am currently only syncing at 29.8Mb.
Right you should be seeing better results on a 17a profile, my attainable rate is 45 but I'm only syncing at 24, I am now waiting to be put 80/20 so that should improve things. if your connection isn't stable at higher speeds that is why DLM is lowering your speeds, to stabilize and reduce errors on your connection, DLM is a nasty thing, I used to be on TT LLU where DLM doesn't exist. All I can say is try 80/20 and see what happens, and ask to be put on a different pair "Lift and Shift" going to the cab if that's not been done already. FTTC is not good on longer lines, BT need to start looking after customers like me and yourself and improve our speeds before spending more money on new installs, everyone in your area will also have problems so know your not allone.
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 15944 Kbps, Downstream rate = 48460 Kbps
Path: 0, Upstream rate = 15851 Kbps, Downstream rate = 54243 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3939)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 15944 kbps 48460 kbps
Actual Aggregate Tx Power: 6.8 dBm 13.6 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 5.4 28.3 42.3 N/A 14.2 34.8 53.9
Signal Attenuation(dB): 8.6 27.3 41.3 N/A 14.2 34.8 53.9
SNR Margin(dB): 5.4 5.3 5.3 N/A 4.3 4.3 4.2
TX Power(dBm): -4.2 -16.8 6.4 N/A 10.7 7.7 5.9
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 16999 Kbps, Downstream rate = 51216 Kbps
Path: 0, Upstream rate = 10000 Kbps, Downstream rate = 39998 Kbps
Attainable Net Data Rate: 16999 kbps 51216 kbps
Actual Aggregate Tx Power: 6.8 dBm 13.2 dBm
Line Attenuation(dB): 5.4 28.0 41.5 N/A 14.2 34.5 53.0
Signal Attenuation(dB): 8.8 27.2 40.2 N/A 14.2 34.5 53.0
SNR Margin(dB): 11.6 11.5 11.4 N/A 9.8 9.9 10.4
TX Power(dBm): -4.3 -16.9 6.4 N/A 10.8 7.8 4.4
@ Bald_Eagle1,
I reset the PPPoE session and ran the BT Speed Test which states that I have an IP profile 44.98Mbps. Upstream rate IP profile is 20Mbps. Actual DL speed achieved during the test was 30Mbps and UL speed was 13.38Mbps. Using Speedtest.net, my actual DL speed was 44.09Mbps and UL was 14.10Mbps.
I have a second line into the house which has business Infinity on it. This is still on the 40/10 service (i.e. not in the speed trial), however the line stats are almost identical (see below). I would kind of expect this to be the case, as it will likely be a similar distance to the cabinet, same cable construction and subjected to simlar levels of noise. I just don't think that the properties of both lines is that great, given the relative distance to the cabinet.
Code:# xdslcmd info --pbParams xdslcmd: ADSL driver and PHY status Status: Showtime Retrain Reason: 2 Max: Upstream rate = 16999 Kbps, Downstream rate = 51216 Kbps Path: 0, Upstream rate = 10000 Kbps, Downstream rate = 39998 Kbps Discovery Phase (Initial) Band Plan US: (0,95) (868,1207) (1972,2783) DS: (32,859) (1216,1963) (2792,3939) Medley Phase (Final) Band Plan US: (0,95) (868,1207) (1972,2783) DS: (32,859) (1216,1963) (2792,3939) VDSL Port Details Upstream Downstream Attainable Net Data Rate: 16999 kbps 51216 kbps Actual Aggregate Tx Power: 6.8 dBm 13.2 dBm ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 5.4 28.0 41.5 N/A 14.2 34.5 53.0 Signal Attenuation(dB): 8.8 27.2 40.2 N/A 14.2 34.5 53.0 SNR Margin(dB): 11.6 11.5 11.4 N/A 9.8 9.9 10.4 TX Power(dBm): -4.3 -16.9 6.4 N/A 10.8 7.8 4.4
One thing that is worth noting is that the cabinet is a long way from the exchange. When on the old ADSL products I was lucky to get 1-2Mbps DL on each service as my house is about 7km from the exchange.
I take it the first connection you mentioned is still reporting this:-
No it isn't. It's now reporting the following:
Max: Upstream rate = 14907 Kbps, Downstream rate = 49012 Kbps
Path: 0, Upstream rate = 14814 Kbps, Downstream rate = 48193 Kbps
I still believe that the attenuation levels appear high for both lines. I'm just wondering if I'm expecting too much based on what I was receiving on the 40/20 service before the 17a profile. Now if only I had line stats from when I was still on the 8c profile....
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 5747 Kbps, Downstream rate = 35008 Kbps
Path: 0, Upstream rate = 5847 Kbps, Downstream rate = 29822 Kbps
Attainable Net Data Rate: 5747 kbps 35008 kbps
Actual Aggregate Tx Power: 6.3 dBm 12.9 dBm
Line Attenuation(dB): 8.3 53.1 64.0 N/A 21.6 63.3 0.1
Signal Attenuation(dB): 14.5 52.5 N/A N/A 21.6 63.3 N/A
SNR Margin(dB): 5.7 5.8 N/A N/A 6.3 6.1 N/A
TX Power(dBm): -4.3 5.8 N/A N/A 10.9 6.5 N/A
Very interesting reading though.# xdslcmd info --pbParams
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 14616 Kbps, Downstream rate = 48908 Kbps
Path: 0, Upstream rate = 15963 Kbps, Downstream rate = 58324 Kbps
Attainable Net Data Rate: 14616 kbps 48908 kbps
Actual Aggregate Tx Power: 6.8 dBm 13.4 dBm
Line Attenuation(dB): 5.4 28.1 42.1 N/A 14.2 34.7 53.6
Signal Attenuation(dB): 8.1 27.2 41.3 N/A 14.2 34.7 53.6
SNR Margin(dB): 5.1 5.1 5.0 N/A 3.0 3.1 3.3
TX Power(dBm): -4.1 -17.0 6.4 N/A 10.8 7.8 5.9
# xdslcmd info --show
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 14623 Kbps, Downstream rate = 48904 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 3.2 5.1
Attn(dB): 0.0 0.0
Pwr(dBm): 13.4 6.8
VDSL2 framing
Path 0
B: 239 223
M: 1 1
T: 64 64
R: 0 16
S: 0.1310 0.4464
L: 14661 4301
D: 1 1
I: 240 120
N: 240 240
Counters
Path 0
OHF: 1217692 358935
OHFErr: 1390 2
RS: 0 1489867
RSCorr: 0 18
RSUnCorr: 0 0
Path 0
HEC: 122 0
OCD: 0 0
LCD: 0 0
Total Cells: 287203237 0
Data Cells: 8350949 0
Drop Cells: 0
Bit Errors: 0 0
ES: 72 2
SES: 2 0
UAS: 16 16
AS: 2564
Path 0
INP: 0.00 0.00
PER: 2.09 7.14
delay: 0.00 0.00
OR: 91.63 31.36
Bitswap: 622 283
