Is there an ISP who offers fibre and who can opt you out of DLM, or do all ISPs offering BT based fibre have to accept the DLM? (I say BT based because Sky, TalkTalk don't even merit talking about).
I've only just had time to look at this again. I've now got HG612 modem stats program running and building up data for the ongoing graphs. Had a slight problem initially with the Windows task schedule that it created, changed it from running "HG612_stats.vbs" to "HG612_stats.exe" and now it's running every minute and seems to be logging data as expected.
Da[]San;23941306 said:Logsi - My stats are very similar to yours except I'm still on Fastpath. I too did have the full 77mbit for a few days, then DLM kicked in and set me down to 60mbit.
You could look at the option to do a soft reboot of the modem when you notice the SNR a bit higher/Sat or Sunday is usually the best day. I did it and so far i'm at 67mbit sync but only 64mbit attainable (current SNR 5.4)
Yes, W8, running fine as far as I can tell. Here is 3 hours and full monty.
Still waiting for DLM to do bring the rate down, of course it will do that looking at the number of errors.
Best I can do is put some dosh aside for FTTP next year!
There is a bit of an issue with W8, in that the scheduled task stops running after a few hours/days.
There are a couple of discussions about that going on in some of the more recent posts here:-
Kitz forum
ThinkBroadBand forum
With Interleaving switched ON at quite a low depth, my DS errored seconds now usually total around 130 or less over 24 hours & CRC/RSUnCorr type errors were replaced by FEC/RSCorr errors.
How would one perform a soft reboot to avoid DLM?
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 13340 Kbps, Downstream rate = 37060 Kbps
Path: 0, Upstream rate = 13236 Kbps, Downstream rate = 36292 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 13340 kbps 37060 kbps
Actual Aggregate Tx Power: 6.9 dBm 13.3 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 5.9 30.8 46.4 N/A 15.1 38.1 58.9
Signal Attenuation(dB): 5.9 30.2 45.3 N/A 15.1 38.1 58.9
SNR Margin(dB): 5.9 6.2 6.1 N/A 6.3 6.3 6.3
TX Power(dBm): -4.6 -12.0 6.5 N/A 11.4 7.8 1.3
# xdslcmd info --show
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 13240 Kbps, Downstream rate = 37060 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.3 6.0
Attn(dB): 0.0 0.0
Pwr(dBm): 13.3 6.9
VDSL2 framing
Path 0
B: 239 237
M: 1 1
T: 64 55
R: 0 16
S: 0.2104 0.5718
L: 9124 3554
D: 1 1
I: 240 127
N: 240 254
Counters
Path 0
OHF: 124256 53570
OHFErr: 0 0
RS: 0 2945525
RSCorr: 0 0
RSUnCorr: 0 0
Path 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 29287340 0
Data Cells: 349713 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 0
SES: 0 0
UAS: 19 19
AS: 421
Path 0
INP: 0.00 0.00
PER: 3.36 7.86
delay: 0.00 0.00
OR: 61.77 32.56
Bitswap: 48 26
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 14559 Kbps, Downstream rate = 62792 Kbps
Path: 0, Upstream rate = 14660 Kbps, Downstream rate = 62576 Kbps
Attainable Net Data Rate: 14559 kbps 62792 kbps
Actual Aggregate Tx Power: 6.7 dBm 13.0 dBm
Line Attenuation(dB): 4.9 26.8 41.2 N/A 13.4 33.1 50.5
Signal Attenuation(dB): 4.9 26.0 40.2 N/A 13.4 33.1 50.5
SNR Margin(dB): 5.9 6.0 6.0 N/A 6.1 6.1 6.1
TX Power(dBm): -4.4 -15.7 6.3 N/A 9.7 7.8 6.9
Max: Upstream rate = 14604 Kbps, Downstream rate = 62792 Kbps
Mode: VDSL2 Annex B
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 6.1 6.0
Attn(dB): 0.0 0.0
Pwr(dBm): 13.0 6.8
VDSL2 framing
Path 0
B: 239 237
M: 1 1
T: 21 64
R: 0 16
S: 0.1221 0.5164
L: 15730 3935
D: 1 1
I: 240 127
N: 240 254
Counters
Path 0
OHF: 1012978 236655
OHFErr: 484 2
RS: 0 2259961
RSCorr: 0 20
RSUnCorr: 0 0
Path 0
HEC: 118 0
OCD: 0 0
LCD: 0 0
Total Cells: 235141624 0
Data Cells: 3607818 0
Drop Cells: 0
Bit Errors: 0 0
ES: 103 28
SES: 1 0
UAS: 152 152
AS: 1957
Path 0
INP: 0.00 0.00
PER: 1.92 8.26
delay: 0.00 0.00
OR: 99.87 30.98
Bitswap: 533 497
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 35927 Kbps, Downstream rate = 119412 Kbps
Path: 0, Upstream rate = 35597 Kbps, Downstream rate = 100015 Kbps
Attainable Net Data Rate: 35927 kbps 119412 kbps
Actual Aggregate Tx Power: - 7.6 dBm 13.9 dBm
Line Attenuation(dB): 3.0 15.1 22.7 N/A 8.4 19.6 29.3
Signal Attenuation(dB): 3.0 14.6 21.0 N/A 8.4 19.6 29.3
SNR Margin(dB): 6.4 6.4 6.3 N/A 12.9 12.0 11.3
TX Power(dBm): -21.8 -17.7 -8.3 N/A 12.0 5.1 7.0
Mode: VDSL2 Annex B
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 11.9 6.4
Attn(dB): 0.0 0.0
Pwr(dBm): 13.9 -7.6
VDSL2 framing
Path 0
B: 239 239
M: 1 1
T: 23 64
R: 0 0
S: 0.0764 0.2146
L: 25138 8948
D: 1 1
I: 240 120
N: 240 240
Counters
Path 0
OHF: 15842907 1218154
OHFErr: 1050 640
RS: 0 4077055
RSCorr: 0 0
RSUnCorr: 0 0
Path 0
HEC: 3108 0
OCD: 0 0
LCD: 0 0
Total Cells: 4028997109 0
Data Cells: 149719032 0
Drop Cells: 0
Bit Errors: 0 0
ES: 165 347
SES: 7 7
UAS: 356 356
AS: 20956
Path 0
INP: 0.00 0.00
PER: 1.31 3.43
delay: 0.00 0.00
OR: 145.72 55.92
Bitswap: 3036 4867
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 30640 Kbps, Downstream rate = 132240 Kbps
Path: 0, Upstream rate = 29186 Kbps, Downstream rate = 69993 Kbps
US: (0,95) (872,1203) (1972,2779)
DS: (32,867) (1208,1971) (2784,4003)
Attainable Net Data Rate: 30640 kbps 132240 kbps
Actual Aggregate Tx Power: - 9.3 dBm 10.7 dBm
Line Attenuation(dB): 2.8 15.9 23.5 N/A 8.1 19.3 29.2
Signal Attenuation(dB): 3.4 15.7 23.2 N/A 8.1 19.3 29.2
SNR Margin(dB): 6.3 6.4 6.5 N/A 22.4 24.1 23.1
TX Power(dBm): -24.5 -19.2 -10.0 N/A 5.7 5.1 6.9
Mode: VDSL2 Annex B
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 23.2 6.5
Attn(dB): 0.0 0.0
Pwr(dBm): 10.7 -9.3
VDSL2 framing
Path 0
B: 239 238
M: 1 1
T: 23 4
R: 0 16
S: 0.1091 0.2602
L: 17592 7840
D: 1 1
I: 240 255
N: 240 255
Counters
Path 0
OHF: 617123615 2106517
OHFErr: 8649 663807
RS: 0 2574261
RSCorr: 0 9623466
RSUnCorr: 0 0
Path 0
HEC: 10422 0
OCD: 0 0
LCD: 0 0
Total Cells: 2297915610 0
Data Cells: 1955219379 0
Drop Cells: 0
Bit Errors: 0 0
ES: 3314 958505
SES: 18 14
UAS: 177 187
AS: 1166392
Path 0
INP: 0.00 0.00
PER: 1.88 4.16
delay: 0.00 0.00
OR: 101.98 92.23
Bitswap: 5485 716175
Tandy? are you serious?thought they went bust on the 90's?
Which cable did you get?
Edit seems they live online now and used ADSLnation for their DSL products... not bad.
