The High speed DSL cable is here and it's added 1.5mb to my attainable rate, not bad really, I wasn't really bothered about the speed, just to tidy the install up and looks much - much neater.
For the price, I recommend it.
Hi all,
I had my 80/20 rated FTTC circuit installed yesterday, my work provided this as a WMBC Wholesale connection.
I am getting around 57mb / 17.5mb throughput (untweaked)
BT have installed the BT Open reach VDSL modem which is B-Focus V-2FUb/r Rev B
What sort of unlocking can I do with these (if any) and will it boost sync speed/throughput?
Can anyone point me in the direction of some reliable guides?
Thanks for the tip; I've just ordered one. It looks to be of much better quality than the ones that are bundled with modems.
Is there a preferred way to connect this new cable without it looking like a disconnection, and therefore possibly affecting the sync speed?
log into the modem - reboot it - before it starts back up (resyncs) - turn it off and install cable.
Need some more people to test this and report.
the update is same method
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 15028 Kbps, Downstream rate = 50740 Kbps
Path: 0, Upstream rate = 10000 Kbps, Downstream rate = 39999 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 15028 kbps 50740 kbps
Actual Aggregate Tx Power: 6.3 dBm 12.2 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 6.2 31.7 47.4 N/A 15.6 39.5 60.1
Signal Attenuation(dB): 6.2 30.8 46.5 N/A 15.6 39.5 60.1
SNR Margin(dB): 9.1 8.9 8.8 N/A 10.5 10.6 10.8
TX Power(dBm): -4.1 -11.0 5.7 N/A 10.0 7.8 -2.3
Isn't too bad for a 600 to 700 meter D-side tbh.
Have you tried the latest firmware?
How you getting measaurements?
Also can you link me to the latest and what does it offer?
