# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status:   0
Max:    Upstream rate = 8818 Kbps, Downstream rate = 48852 Kbps
Bearer: 0, Upstream rate = 8703 Kbps, Downstream rate = 43354 Kbps
Discovery Phase (Initial) Band Plan
US: (6,31) (882,1193) (1984,2770)
DS: (33,857) (1218,1959) (2795,4083)
Medley Phase (Final) Band Plan
US: (6,31) (882,1193) (1984,2425)
DS: (41,857) (1218,1959)
                  VDSL Port Details               Upstream                Downstream
Attainable Net Data Rate:            8818 kbps              48852 kbps
Actual Aggregate Tx Power:             5.2 dBm               12.6 dBm
        VDSL Band Status                U0              U1              U2              U3
U4              D1              D2              D3
  Line Attenuation(dB):  2.6     36.9    55.5     N/A     N/A    17.6    47.0    73.1
Signal Attenuation(dB):  2.6     36.8    53.9     N/A     N/A    22.7    46.7     N/A
                SNR Margin(dB):  6.5     6.0     6.2      N/A     N/A    5.6     5.5      N/A
                 TX Power(dBm): -3.6    -5.1     4.1      N/A     N/A    11.0    7.4      N/A
# xdslcmd info --show
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 8815 Kbps, Downstream rate = 48852 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        5.6             6.1
Attn(dB):        23.0            0.0
Pwr(dBm):        12.6            5.2
                        VDSL2 framing
                        Bearer 0
MSGc:           18              28
B:              51              238
M:              1               1
T:              64              31
R:              12              16
S:              0.0382          0.8733
L:              13416           2336
D:              849             1
I:              64              255
N:              64              255
                        Counters
                        Bearer 0
OHF:            6587278         1193412
OHFErr:         23              0
RS:             1686239825              966387
RSCorr:         1428568         8
RSUnCorr:       1738            0
                        Bearer 0
HEC:            432             0
OCD:            19              0
LCD:            19              0
Total Cells:    1346464946              0
Data Cells:     4738237         0
Drop Cells:     0
Bit Errors:     0               0
ES:             6               0
SES:            0               0
UAS:            23              23
AS:             16153
                        Bearer 0
INP:            3.00            0.00
INPRein:        0.00            0.00
delay:          8               0
PER:            2.45            13.58
OR:             78.30           20.01
AgR:            43432.34        8723.63
Bitswap:        12467/12467             2/2
