Post your FTTC line stats & unlocking info
Thanks, it now unlocked. Do I need to input username / password on BT Openreach Modem WAN for FTTC? As I have Netgear DGND3700v2 as I will using this router for wifi.
Just got my first router with integrated VDSL modem, first time I've had access to stats -
Code:
root@SRX110> show interfaces pt-1/0/0 extensive
Physical interface: pt-1/0/0, Enabled, Physical link is Up
  Interface index: 148, SNMP ifIndex: 532, Generation: 151
  Type: PTM, Link-level type: Ethernet, MTU: 1518, VDSL mode, Speed: VDSL2
  Device flags   : Present Running
  CoS queues     : 8 supported, 8 maximum usable queues
  Hold-times     : Up 0 ms, Down 0 ms
  Current address: 54:e0:32:d2:5c:a0
  Last flapped   : 2014-01-31 23:14:16 GMT (18:31:43 ago)
  Statistics last cleared: Never
  Traffic statistics:
   Input  bytes  :                  132                    0 bps
   Output bytes  :             14227217                    0 bps
   Input  packets:                    2                    0 pps
   Output packets:                62763                    0 pps
  Input errors:
    Errors: 0, Drops: 0, Policed discards: 0, L3 incompletes: 0, L2 channel errors: 789, L2 mismatch timeouts: 0, Resource errors: 0
  Output errors:
    Carrier transitions: 1, Errors: 0, Drops: 0, Aged packets: 0, MTU errors: 0, Resource errors: 0
  Egress queues: 8 supported, 4 in use
  Queue counters:       Queued packets  Transmitted packets      Dropped packets
    0 best-effort              3944553              3944551                    2
    1 expedited-fo                   0                    0                    0
    2 assured-forw                   0                    0                    0
    3 network-cont                9466                 9466                    0
  Queue number:         Mapped forwarding classes
    0                   best-effort
    1                   expedited-forwarding
    2                   assured-forwarding
    3                   network-control
  VDSL  alarms   : None
  VDSL  defects  : None
  VDSL media:            Seconds        Count  State
    LOF                          0            0  OK
    LOS                          0            0  OK
    LOM                          0            0  OK
    LOP                          0            0  OK
    LOCDI                        0            0  OK
    LOCDNI                       0            0  OK
  VDSL status:
    Modem status  : Showtime (Profile-17a)
    VDSL profile  :     Auto    Annex B
    Last fail code: None
    Subfunction   : 0x00
    Seconds in showtime : 244
  VDSL Chipset Information:               VTU-R                  VTU-C
    Vendor Country :                       0xb5                   0xb5
    Vendor ID      :                       BDCM                   IFTN
    Vendor Specific:                     0x9385                 0xb203
  VDSL Statistics:                        VTU-R                  VTU-C
    Attenuation (dB)         :              0.0                    0.0
    Capacity used (%)        :                0                      0
    Noise margin (dB)        :              8.5                    9.5
    Output power (dBm)       :             13.5                    4.5
                                  Interleave       Fast  Interleave       Fast
    Bit rate (kbps)   :                    0      79999           0      20000
    CRC               :                    0          0           0          0
    FEC               :                    0          0           0          0
    HEC               :                    0          0           0          0
  Packet Forwarding Engine configuration:
    Destination slot: 0 (0x00)
  CoS information:
    Direction : Output
    CoS transmit queue               Bandwidth               Buffer Priority   Limit
                              %            bps     %           usec
    0 best-effort            95       19000000    95              0      low    none
    3 network-control         5        1000000     5              0      low    none
  Logical interface pt-1/0/0.0 (Index 80) (SNMP ifIndex 533) (Generation 145)
    Flags: SNMP-Traps VLAN-Tag [ 0x8100.101 ]  Encapsulation: PPP-over-Ethernet
    Traffic statistics:
     Input  bytes  :                  132
     Output bytes  :                  148
     Input  packets:                    2
     Output packets:                    2
    Local statistics:
     Input  bytes  :                  132
     Output bytes  :                  148
     Input  packets:                    2
     Output packets:                    2
    Transit statistics:
     Input  bytes  :                    0                    0 bps
     Output bytes  :                    0                    0 bps
     Input  packets:                    0                    0 pps
     Output packets:                    0                    0 pps
    Security: Zone: untrust
    Allowed host-inbound traffic : bootp dns dhcp finger ftp tftp ident-reset http https ike netconf ping reverse-telnet reverse-ssh rlogin rpm rsh snmp snmp-trap ssh
    telnet traceroute xnm-clear-text xnm-ssl lsping ntp sip r2cp
    Flow Statistics :
    Flow Input statistics :
      Self packets :                     0
      ICMP packets :                     0
      VPN packets :                      0
      Multicast packets :                0
      Bytes permitted by policy :        0
      Connections established :          0
    Flow Output statistics:
    Flow error statistics (Packets dropped due to):
      Address spoofing:                  0
      Authentication failed:             0
      Incoming NAT errors:               0
      Invalid zone received packet:      0
      Multiple user authentications:     0
      Multiple incoming NAT:             0
      No parent for a gate:              0
      No one interested in self packets: 0
      No minor session:                  0
      No more sessions:                  0
      No NAT gate:                       0
      No route present:                  0
      No SA for incoming SPI:            0
      No tunnel found:                   0
      No session for a gate:             0
      No zone or NULL zone binding       0
      Policy denied:                     0
      Security association not active:   0
      TCP sequence number out of window: 0
      Syn-attack protection:             0
      User authentication errors:        0
  Logical interface pt-1/0/0.32767 (Index 82) (SNMP ifIndex 539) (Generation 147)
    Flags: SNMP-Traps VLAN-Tag [ 0x0000.0 ]  Encapsulation: ENET2
    Traffic statistics:
     Input  bytes  :                    0
     Output bytes  :                    0
     Input  packets:                    0
     Output packets:                    0
    Local statistics:
     Input  bytes  :                    0
     Output bytes  :                    0
     Input  packets:                    0
     Output packets:                    0
    Transit statistics:
    Security: Zone: Null
    Flow Statistics :
      Self packets :                     0
      ICMP packets :                     0
      VPN packets :                      0
      Address spoofing:                  0
      No minor session:                  0
      No more sessions:                  0
      No NAT gate:                       0
      No route present:                  0
      No tunnel found:                   0
      Policy denied:                     0
Think I'm about 320 metres from the cabinet.
Just had my sky fibre connection go live today, syncing at 40/10 but getting 18/10 on various speedtest sites.
My stats are below...
Broadband Link Downstream Upstream
Connection Speed 39998 kbps 9999 kbps
Line Attenuation 7.8 dB 0.0 dB
Noise Margin 25.9 dB 31.31 dB
Any idea what sort of speed i should be able to get when DLM finishes its initial run?
That's pretty poor speed (sound like up to 24Mbps ADSL2+) as for DLM won't be kicked in the day after new install. Are u using wireless? Try it with ethernet direct from your sky router to your pc or laptop.
There is nothing wrong with the connection from you to the cab very good stats. As you say there is a problem with throughput.
Yup, using the WiFi from the sky hub :/ Ordered a 15m cat5e cable long enough to reach the PC, should be here Tuesday courtesy of the fine chaps at OcUK :) The shop being so close is the only thing I miss about living in Stoke on Trent, now I'm back in Southport I have to rely on my lovely free postage, the local pc component stores are woeful in comparison.... Says a lot when Screwfix sell cat5e cheaper than them :)
In recent days, after a long period of a settled sync and SNR, I noticed my attainable rate had increased again and, at my current sync, I had an SNR of around 8 down and 7.5 up. That lasted for a good day so I decided to run a longer graph and see what was happening.
This is what I got:-
If there was a fault, I would have expected a lower value fluctuation instead of flicking between my established values and those that are higher?
Any insights?
Code:
  Traffic statistics:
  Input errors:
  Output errors:
    0                   best-effort
    3                   network-control
  VDSL  alarms   : None
  VDSL  defects  : None
    LOF                          0            0  OK
    LOS                          0            0  OK
    LOM                          0            0  OK
    LOP                          0            0  OK
    LOCDI                        0            0  OK
    LOCDNI                       0            0  OK
  VDSL status:
    Subfunction   : 0x00
    CRC               :                    0          0           0          0
    FEC               :                    0          0           0          0
    HEC               :                    0          0           0          0
  CoS information:
    Direction : Output
                              %            bps     %           usec
    Traffic statistics:
     Input  bytes  :                  132
     Output bytes  :                  148
     Input  packets:                    2
     Output packets:                    2
    Local statistics:
     Input  bytes  :                  132
     Output bytes  :                  148
     Input  packets:                    2
     Output packets:                    2
    Transit statistics:
    Flow Statistics :
      Self packets :                     0
      ICMP packets :                     0
      VPN packets :                      0
      Address spoofing:                  0
      No minor session:                  0
      No more sessions:                  0
      No NAT gate:                       0
      No route present:                  0
      No tunnel found:                   0
      Policy denied:                     0
    Traffic statistics:
     Input  bytes  :                    0
     Output bytes  :                    0
     Input  packets:                    0
     Output packets:                    0
    Local statistics:
     Input  bytes  :                    0
     Output bytes  :                    0
     Input  packets:                    0
     Output packets:                    0
    Transit statistics:
    Flow Statistics :
      Self packets :                     0
      ICMP packets :                     0
      VPN packets :                      0
      Address spoofing:                  0
      No minor session:                  0
      No more sessions:                  0
      No NAT gate:                       0
      No route present:                  0
      No tunnel found:                   0
      Policy denied:                     0
How to get this stats? I would like to see mine too
What a load of rubbish talk from you. The line is look excellent.
According to speedtest, there is nothing wrong with the line.
You're achieving max speeds and your ping is 11ms that is far too high...
EDIT: Have you not sensed the sarcasm yet? :D
