And still nobody has commented on my beautiful riser cable with annoying creases in it. God damn hippies!
I dunno man its a bit of a weak machine compared to mine so it will be disappointing I am sure![]()
Yep I have £200 tickets to see faith no more in July alsoI have tickets to see them at the royal albert hall in July...![]()
Not happy about the creases in your riser cables mind !
aw man it doesn't look too bad to be fair and I still have a FM2 X2 black edition and it's still fast as my primary machine.
What you waiting for now? You just need your cpu in n cooler.
Wait for the tapeRight RAM, lets talk RAM!!!
So i was playing about that set with purple dots and me messing about have been painted probably 5 times. The plan was the little triangles at the bottom and a line across the bottom that is raised purple but with the current masking tape situation that is not happening. So do I:
- Wait for the tape
- Go just white
- One half of the RAM White, the other half purple?
- Pancake
Wait for the tape
Amount of effort you are putting in might as well do it right
You mean half white half purple
On each side
Diagonal line dividing the colours?
LolNooo I mean properly half and half. give me 5 mins and this should be dry enough to show you.
Lol
Half and half horizontal or vertical
What about frog tape?
I'll stick you on it and spray you purple 50/50![]()
Ahhhhh either side
Not half and half on same side lol
Bit pedantic I know
But white side looks slightly bent
