@melmac & @koh thank you both
So downstairs I would plug a powerline adaptor into a wall socket near to the BT Homehub and then attach it to one of the lan ports on the Homehub using a patch cable.
Upstairs I would plug the 2nd powerline into a socket near my pc and attach this using another patch cable to the Archer AX1800 (presumably via the WAN port?), and then plug the AX1800 into the PC (presumably using a lan port on the AX1800?)?
Is the AX1800 now an "Access Point" in this scenario?
Is this how it should look?
BT Homehub - powerline - [....dodgy home wiring....] - powerline - AX1800 - PC
or
BT Homehub - powerline - [....dodgy home wiring....] - powerline - PC - AX1800
I guess this mean I can ditch my mobo's onboard wifi for my usual PC online stuff since my PC will be attached to the AX1800?
Is this how it works in n00b-speak?:
My BT Homehub sends both the 2.4Ghz & 5GHz wifi signal through the house but I password protect the 5Ghz band on the Homehub so rest of the household can only access the 2.4Ghz band. I also password protect the AX1800 to make sure no one else can access the 5Ghz band from there.
Will my PC use just 2.4Ghz for browsing/gaming etc, leaving the 5Ghz available on the AX1800 soley for Quest 2 Virtual Desktop usage, or should my PC be able to use the 5Ghz band too?
Sorry for all the questions![]()
Plug the 2nd powerline into an ethernet port on the AX1800 not the wan port.
and connect a network cable from the PC to the Ax1800 too. That way you won't be using wireless for Internet on your PC.
ON the Ax1800 setup the 5Ghz network with a password and only use that password on the Quest 2.
