Just call me cavey wavey![]()
Great, another one claiming glitches in his tracking for golf. In between the laser assisted shots.Don't tell me you bought one???
I had to get my Quest 2 replaced because of dead or stuck pixe on left lens, but the replacement display didn't seem right compared to old, too bright, even when I turned down brightness, Luckily an online search told me about the contrast slider hidden away in the accessibility in settings, there is a colour correction there as well. So a little bit of contrast and everything is fine now.Let me just put this in perspective. I've just packed up my Quest Pro to get a replacement as it had a couple of minor faults (speaker hiss and slightly dodgy tracking of the left eye - I paid full price, so I expect it to be perfect), and I've gone back to my Quest 2 to try to get some saves transferred over.
On trying the Quest 2 after playing nothing but the Pro for weeks I was struck by how blurry the lenses were, especially at the edges, there's horrible godrays and glare - I can see the fresnel rings, the picture is soft and the colours washed out with grey blacks. The FOV felt tiny and restrictive, and having the headset clamped to my face felt claustrophobic.
I used to think the Quest 2 looked amazing, now I think it looks and feels primitive by comparison to the Pro.
Yeah i thought so much, well after some Dutch courage and permission from her indoors to spend my money whilst I can. I have ordered a new psu, 4090 and 5800x3D from here. I went with a PNY 4090 after looking at the sizes that might fit my computer case as it was the smallest and there are no FE cards in stock. My aim will be to watercool the 4090 at some point as my current 1080ti is on water, but i just want to stretch the pro as far as i can at the moment and i dont mind any fan noise.To do the Quest Pro justice youi need a meaty GPU, and preferably an Nvidia one as the viideo encoding is much better.
Minimum for really good results would be a 3080, but even then you're not going to run all VR games maxed out. Only the 4090 seems able to max out most games, and even then some VR games never run that well due to bad optimisation.
I really want a 4090 to replace my 3090 for use with the Pro, but I'd also have to get a new PSU too which increases the hassle and cost.
my Antec 850 gold is fine.Yep, I was kicking myself as I bought an 850w when I got my 3080Ti. I said at the time maybe I should go 1000w but decided not to.
Whilst an 850 would have probably been ok, some sites were saying not to risk it, so I ended up getting a 1000w which added to the already high cost.
Oh well, we only live once
Tell you what though, was worth every damn penny! It's so much better now.
