QUOTE="danpmalpass, post: 36307997, member: 263723"]
I've come here in the hope that someone may be able to help me. I've tried averywhere I can think of an still no joy, approxiamately 100 combined hours of tryi to fix this problem.
When using an Meta Quest Pro, with Assetto Corsa Competizione, the Oculus overlay is reporting that I'm running at a solid 80hz, with 99% headroom, yet I have constant stuttering. Even when the resolution is set to its lowest, abnd all in game settings are at their lowest, the stuttering persists.
My solution so far has been to dissable Global C-State Control and core performance boost in the bios, and set Dynamic preffered cores to Frequency. This has had a huge impact, and reduced the stuttering immensly. However, there is still the occassional micro stutter.
Would anyone have any suggestions on what other bios setting I may be able to change, to eliminate the stuttering completely?
Many thanks
[/QUOTE]
Are you wired or wireless? What GPU/CPU?
Have you tried closing down all unnecessary apps as I find they can cause framerate hitches.
