Possibly. From Nvidia, the performance uplift from the 3070 to 4070 just wasnt enough. For me the only Nvidia card that would have been worth it from a performance perspective was the 4080, but there is no way on earth I am paying £1,200 for a graphics card.
I bit the bullet and I have purchased a 7900XT. Will be good to try AMD again after many years. Last AMD card was a 4850 back in the day. Should be a bit of an upgrade from my 3070.
I wonder if EVGA could have saved the 4070?
I think the fact that at stock the TDP is just 200w, seemed like a warning sign in terms of performance. Even if the efficiency is great.
These cards probably could've had a TDP of ~260w, with higher boost clocks.
That power consumption though and just as summer is coming, bad deal IMO.6950XT now at same price.
Lowering performance to save power? You can do that on a 4070 too.There's features like Radeon Chill, and their Software suite if your concerned about power consumption. But now that's its a major SP eh @CAT-THE-FIFTH I guess lets focus on that!![]()
Right, the RX 6800 is 223 watts board power consumption, compared to 201 watts. the 6800 has 2 more 32Bit lanes and memory IC's, that will acound for about 15 watts.
The 4070 is 16% faster, a whole 16%, it makes the 4070 about 25% more efficient, much less if you take in to consideration the memory architecture differences.
One is on 7nm, the other on 5nm, when you apply some critical thinking to it, its not great, i would not have apologized "but its really efficient" like some of these tech jurnos did, maybe if it was 150 watts, to me it should be closer to that on such an advanced node given its performance.
when people cry foul and reach straight for the power bug slides.....RX 6800 is 250W board power at stock.
If you are using the sensor reported power consumption it ignores memory.
AMD Radeon RX 6800 Review
The Radeon RX 6800 is the world's most power-efficient graphics card, better than anything NVIDIA Ampere has to offer. The smaller brother to the RX 6800 XT comes with a smaller heatsink, at more affordable pricing, but retains the lavish 16 GB VRAM memory buffer.www.techpowerup.com
Sustained furmark is measured at 254W, which is within margin of error of AMDs stated TDP.
When not CPU bound it will reach that.
edit:
I'm guessing you might be using the gaming average. Which is a fair comparison. But it does need to be the same setup between the 6800 and 4070 to be a comptely fair comparison.
I would look for more recent like for like tests. Might still be 25%.
Good job you edited that
Yes, gaming average, no one sits playing furmark all day, the RTX 4070 is 201 watts also average gaming.
TDP is meaningless, Intel's 220 watt CPU's have a 95 watt TDP.
But it depends on the game used for that test, and also the CPU used. I think there are fairer more up to date comparisons out there.
Nvidia GeForce RTX 4070 review: an RTX 3080 challenger for $599
The Digital Foundry review of the Nvidia RTX 4070, looking at performance, power efficiency, RT, DLSS 3 and more. This page: design, power efficiency testing.www.eurogamer.net
Here you can see it is 35% more efficient than the RTX 3080 with RT Off. RDNA2 was something like 20% more efficient than Ampere.
So 0.65/0.8 is something like 20%.
