For the first time since I've owned my Note, I got a message today saying software update available. I downloaded it (around 70mb) but it didn't install for some reason, it said try to update again via kies. Anyone else get this update and what it is?
What you guys using for tV? other than the standard iplayer etc
It depends where you bought your Note from and what your current firmware is. My Note is from Germany and has had regular OTA updates, but for some reason the rest of Europe has been left way behind.
If this is your first update in a while then I definitely recommend it. It should have better performance, faster wake-up time and a number of other tweaks like updates to the S Memo app and Swype.
Question for you Note girls:
Now you've had your Note a while and are used to it, what do you make of the S-Pen?
Be honest, would you miss it if the Note 2 didn't have one? Have you come to use it often?
I don't use it much at all really, just a bit of drawing with my 2 year old, he likes drawing moustaches on people etc. I'm sure this wasn't the kind of use Samsung had in mind though.![]()
