Whats that little part?
One of the SIM contacts, which in turn means the phone won't detect or read any simcards...
Any idea when we're getting ICS on this?
The message also stated that Ice Cream Sandwich would be made available "soon" for a number of other Samsung devices such as the Galaxy Note, the Galaxy S II LTE, and the 8.9 and 10.1 versions of the Galaxy Tab tablet product.
Just got my one about an hour via amazon.de, bloody awesome bit of kit btw. It came with a euro plug, would any uk pkug to usb adaptor suffice ?.
just ordered one from amazon.de, can anyone recommend a good case ?.
i've read about a lot people ordering from amazon.de, is that really wise in the long run? if the phone goes wrong do you have to call a german call center and does it effect the warranty if purchased from another country?
Earth[Tera].bin;21482084 said:Just received mine from Amazon.de , with the saving I purchased a 64Gb microsd card at the same time.
To use in the Note? I thought the note could only use 32gb max.
ICS? Please enlighten me
Aside from vanilla ICS UI not sure why people are so excited about ICS I've played with my note on Gingerbread 2.3.6? and one using ICS 4.1 release candidate? and there was very little difference aside from some fairly minor increases in performance/response, fairly small tweaks to notifications and settings and nothing else I could see at all from a quick glance.
Earth[Tera].bin;21483448 said:Nah, both the note and GSII can handle 64GB. Just pop it in and get the device to format the card. Filesustem support was limited to FAT32 but you can now use NTFS-3G for NTFS support.
Been using 64GB in mine for a few months now, it works fine.
WHERE IS ICSSS
What 64gb card are you using?
