Samsung Galaxy Note: 5.3", 1200x800 SuperAMOLED, S-PEN stylus, 2500mAh attery... *phew*
3g watchdog - keep track of your data usage
Boat browser - best browser I've tried, very fast
BSplayer - Good video player with gesture controls
Dolphin browser - another alternative browser, really well laid out with some cool features. I tend to use Boat though as it's faster
ES file explorer - the best android file explorer, as well as viewing your sd card you can access your LAN and ftp.
GPS status - show off the notes super fast GPS
Poweramp - THE best music player for android
Quickpic - The stock android gallery is terrible, this is much better
TuneIn radio - online radio
And make sure you enable the Swype keyboard!
My Galazy Note finally arrived!
The screen is flipping MASSIVE... But I love it already..
Can members please advise me on some apps
Get yourself samsung hub and also go on samsung apps there's exclusive apps and freebies for the Note and on hub if you look around there's £120 of movie and music vouchers, they used to be for purchase but afaik they still work for renting off samsung movies.
Thank you for your recommendations!
Installed most of them for now...
A few questions, if I may..
1. What bloat wear can i uninstall, any lists?
2. Recommended software for ripping music for my Note, or is it easy too transfer my entire iTunes libary?
Where do I put ripped music? Folder "usbstorage"
https://spreadsheets.google.com/spr...SENVeXlqUm5vV0E&single=true&gid=0&output=html
That's a list of installed apps/bloatware. I'd suggest freezing them first in Titanium backup to check it doesn't cause any issues. Then after a little while of normal use you can go back and delete them.
Another handy alternative is this: http://forum.xda-developers.com/showthread.php?t=1478918&highlight=lite+rom+creator. You can generate a little script that removes any apps you don't want. I found it very handy when i was switching around between ROMs, i could just get rid of the junk straight away.
Thank you guys.
How do I move the locations of "Phone, Contacts, S Memo, Messaging, Applications" on the very bottom of the screen.
They seem too be stuck, an I dont like the present locations!
The news is good, ICS being rolled out today for Galaxy Note, Europe first, German Notes are getting it as I type.
I hope it's better implemented than it is on the S2 - made mine laggy as hell - S2 is better on GB.
Weird. My S2 feels better on ICS, better battery life too. I did do a full on back to factory reset though. The first attempt resulted in a few bugs (flash not working on websites for example).
Got my Note this morning and wow what a phone. Not missing my SGS2 in the slightest, can't believe I waited this long.
