Samsung Galaxy Note: 5.3", 1200x800 SuperAMOLED, S-PEN stylus, 2500mAh attery... *phew*
I've read of similar probs when using some car chargers, it might be the battery itself you could take it to a shop and try another battery or totally disharge then recharge yours, may be a factory reset might help with a calibration issue, other than that dunno soz.
I haven't been chargin from a Car charger!
Generally (80%) of all my charge cycles have been Calibration charges.
(Full Discharge + 100% Charge, then disconnect.)
Nearly all are on the Main charger, or via USB.
Its was very weird.
The constant popping up of "Chargin Stopped. Voltage too high." warning message every 5-10 secounds,
forcing the screen too remain on constantly!
As a result the CPU/GPU region was very hot (Despite ALL active processes been terminated)
An the phone ate through its battery very quickly! From 80% Charge at start of problem, too 50% charge in 40 minutes! :o
Several Recommendation I found online too resolve issue!
I didn't attempt all proposed solution. Thought I would document them:
1. Power Off Phone, an remove Battery. With intention too allow phone/battery too cool down! (Found online)
2. Restart phone. (Found Online)
3. Discharge phone battery, an complete calibration charge. (100% Charge)
4. Save SD Contents, an Restore phone too factory defaults!
5. Try different Charge, or connect phone too different charger!
In the end, the phone randomly stopped doing it!
I had too return too work, so put it on silent + No vibrate an stuck it in my pocket. After an hour an almost completely using the battery it stopped prompting me!
Will invest in new battery soon, an a secound charger, so I dont have to worry about dodgy charger/battery. Especially as its a German Note, I dont want too have too send it back...:mad:
Hope this helps some one in the future..
Hi i have an issue with my note.
Before i could connect to the play store/ skype or sign into ebay with 2 bar of reception. Sometimes it wouldnt connect but it would try to connect.
Now when i try it it says no network connection detected. Im on 3 btw and i haven't seen the 3g of H symbol for two days now. I just noticed the issue yesterday
Yay just got my Note :D
First thought was "**** me that's huge!".
Second was "why does it only have a european adapter?"
But other than that seems very nice, haven't had much of a chance to play with it yet though.
Just installed CM9 nightly, what can I say other than awesome! Makes the note into a whole new device compared to GB.
Edit: haha, mum just came in from work "Thats not a phone!" :D
Me? Na, got it from the rainforest. It was only £25 more (after postage), which I thought was worth it considering it's quicker postage, better warranty (don't have to send the phone to China), plus I trust them (been stung before buying expensive electronics direct from China).
p.s. Just looked at the rainforest and they've dropped the price by £25 two days after I bought it! The buggers!
damn damn damn :S ill get it next month doom it..! everyone is loling at me when i speak about it but i want it so bad :(
Email them, Ive heard a couple stories where they refund the difference, say its unfair or something.
Been using the S3 alongside the Note for the past half hour, and although I am very happy with the Notes performance since upgrading to ICS (except the battery life), the S3 is much more fluid when scrolling through menus. They have done really well to get such a big screen (only half an inch smaller) into a device which is a fair bit smaller then the Note. I will be keeping my Note and see what the Note 2 offers but it's nice to also have an S3 to play with (got it for the missus).
