Samsung the benders have removed the Brightness slider from the status bar - why remove it? Mind boggling.
They have added the battery percentage though.
I've never seen.any.of those features lol
A factory reset would probably sort it, bit of a pain though I know! I think the consideration needs to be that this is a bit pretty major update, like going from XP to 7 or something. Starting afresh is the best way to make sure everything is working ok.
Yeah, from O2 online store. Hope this doesn't mean I'm, going to get stuck waiting for some branded crappy O2 ICS release? I was under the impression that the Notes are sent out unlocked...
Anyone getting GPS lock issues? MY gps doesn't seem to be working at all with GPS TEST app? Can't see any sattelites and no gps icon in status bar
edit - working now after a reboot.
I've found GPS signal significantly worse in ICS, just like battery life.
I'm considering going back to GB at this point, but waiting to see if Samsung release a newer build anytime soon.
In no hurry to move to ICS myself, I think some people must have some crappy GB firmware revision(s) - my UK one is a lot smoother and more responsive than those I know IRL who got theirs from the de store (using latest stock firmware).
I bought a couple of solar chargers from eb by way of China 5000ma/h, £15 each 1 for me and 1 for the lads primarily for the 7.7s, both work fine one of them has put 30% on my note in about 30/40 min the other has put 5% on a 7.7 in 8 min, I paid attention that time.
They're smaller than the Note, about as thick as mine in its silicone cover, and would be totally convenient to carry around even use one on the move, I'm mega pleased with the purchase and the free charging it brings![]()
How have yours served you? Are they any good? Going away camping for 5 days at the end of June and considered one, but I've also just bought 2 extra batteries and will have access to a 12v plug on the odd car journey. Two minds on whether to buy one or not
Yup they both work fine, getting charge from the sun and charging the Note or 7.7s fast.
