Galaxy S3 design - please no.
a couple of questions, heavy use my desire hd being the battery whore it was would see me from unplug at 7am to around 1 or 2pm with lighter use around 6 or 7pm before needing to charge, how does the galaxy note fare against them kind of numbers?
secondly, ill be looking to root and flash a clean version of ICS, i did this with gingerbread and ICS on my desire and also flashed new radios etc, should this be straight foreword on the Note and what if any functionality would you loose?
Thanks ethos for the update.... At the moment I don't find the device slow enough to warrant a custom rom but we'll see how I get on by the end of July
BTW roms @ xda or modaco ?
if i was to flash this and then update to the Stable (when its out) would i have to do a reflash again and start from scratch?
I got my ROM from here (if that question was referring to CM9!).
http://get.cm/?device=n7000
Nope:
Upgrading from earlier version of CyanogenMod 9:
- Copy CM9 ZIP to your internal SDCard
- Boot into Recovery
- Flash CM9 zip
- Wipe cache partition and dalvik-cache
- Reboot
steve - maybe this can help: http://forum.xda-developers.com/showthread.php?t=1656705
Have you tried a factory reset?
Ok got it sorted, loving the note and its silky smooth, opted for paranoid android for its tablet hybrid settings and very very pleased.
friends are already disgusted at the shear size of it so that's a bonus![]()
