Caporegime
- 18 Oct 2002
Does anyone know if these are using an improved 2nd-gen QD-OLED panel or the same tech as the OG 34?
Yes they are 2nd gen QD OLEDDoes anyone know if these are using an improved 2nd-gen QD-OLED panel or the same tech as the OG 34?
Great thanks, just wondering really.Yes they are 2nd gen QD OLED
ignore me, found it. 100*100Does the monitor have a standard vesa mount on the back? Can't seem to find that detail anywhere.
Yeah that's ridiculous, I got told I had to cancel the order and order again so that's what I did.Because i ordered online they cannot provide a refund of the price difference they can only do so if you order via the phone.
Yeah luckily waiting to dispatch at the moment. Ordered just before 4pm yesterday.Was it still in stock when you ordered again?
Yep, going to cancel I have a macbook air so only 2 USB-C ports, so hooking up to display and power will use both those up. So will end up needing a USB-C powered hub and a KVM switch.... that's too much faff.Gah, just realised that i'm going to need to buy a KVM switch now to share USB devices between desktop and macbook this might actually be a deal breaker for me, I can't remember what I used to do with my older G9 must have used bluetooth back then :S
I've been using a 38 inch dell which has a builtin KVM and usb-c hookup to my work laptop and it is excellent. I can't understand why a latest generation monitor doesn't have KVM & usb-c with PD. It's got to be that manufacturers think we either want a gaming screen OR a business one and not both so don't bother with the connectivity that is required for both use cases.Yep, going to cancel I have a macbook air so only 2 USB-C ports, so hooking up to display and power will use both those up. So will end up needing a USB-C powered hub and a KVM switch.... that's too much faff.
Edit: Turns out the MSI and Asus versions of this both have USB-C with 90w PD so they might be the ones for me.
Yeah, it's a hard requirement for me. I swear I saw something that said it have USB-C or it would have been a no-go from the start... oh well, hopefully my cancelling will have allowed someone else to snag it now I just need to see if I can wait for the MSI or Asus version to come out or if i'll folder and go wit the Philips I saw in OcUK B Grade.I've been using a 38 inch dell which has a builtin KVM and usb-c hookup to my work laptop and it is excellent. I can't understand why a latest generation monitor doesn't have KVM & usb-c with PD. It's got to be that manufacturers think we either want a gaming screen OR a business one and not both so don't bother with the connectivity that is required for both use cases.
Just been digging into the Asus spec and it only has HDMI 2.0 and 144Hz. The 144Hz doesn't bother me at all, but the 2.0 does.Yep, going to cancel I have a macbook air so only 2 USB-C ports, so hooking up to display and power will use both those up. So will end up needing a USB-C powered hub and a KVM switch.... that's too much faff.
Fair enough, hopefully you're right. Just don't want to waste a day off work not to receive it.It wont come until monday, you will get notice on the sunday....
I've got this wrong, the PG49WCD does have HDMI 2.1Just been digging into the Asus spec and it only has HDMI 2.0 and 144Hz. The 144Hz doesn't bother me at all, but the 2.0 does.
Heads up just got notification mine being delivered tomorrow
